5.3 Twin On3 70mm's
Old Sep 21, 2012 | 07:20 PM
  #61
T76s10's Avatar
Originally Posted by 71 chevy
I prefer ideal setups over worst case scenarios.
Yeah i totally agree. I wouldn't think about doing twin gt45's but if he wants to do them I'm saying the nitrous would make them somewhat usable for the strip. On the street, i think it would suck *** to do twin gt45's. The on3 70's will do just fine for wicked. Me personally would do the 61's because i drive on the street all the time and want instant boost.
Old Sep 21, 2012 | 07:48 PM
  #62
Sarg's Avatar
Do you have a link for the 61's?
Old Sep 21, 2012 | 08:24 PM
  #63
71 chevy's Avatar
Originally Posted by Wicked69
It's kind of hard to go against 71 chevy. He has done this and run some damn good times. A good point is the 70's would bolt right on with no modifications. The GT45's would need some modifications and definitely need the nitrous. So probably is just better to sale the nitrous kit cheap and get the ON370's. This way it would be good on both the street and the strip.
Lots of good input but I'll go ahead and give the on3 70's a shot first.
Thanks for the kind words. ive been overturbo'd and overcammed,
then underturbo'd and undercammed, and going under is more fun than going over
Old Sep 23, 2012 | 06:39 PM
  #64
Tjabo's Avatar
Originally Posted by a-low
Dang that looks like the size of a BW turbo. Any idea on how much it weighs?
Mine just got delivered and it is HEAVY! The UPS man commented that it seemed heavier than the 25# it said on the label. After I had put it back in the box and taped it up I remembered I wanted to weigh it. The box was sufficient, but not real heavy so I just weighed it all together. 35 pounds!
I doubt the box and packing adds up to 2 pounds (EDIT: I had to unpack the turbo to measure it for a downpipe V-Band flange, so I weighed it while I had it out of the box and sure enough, 33#), so this is a seriously heavy turbo. Having said that, I just read some of the recent threads on turbo explosions and it caused me to think that some mass in a turbo might not be a bad thing if it is in the turbine housing, etc...
And one other observation, I've had quite a few turbos over the years, and this one seems very nice quality in comparison to the others that I've had (most recently a nice billet wheel Precision that smoked, but did not blow up. Lol).
Old Sep 23, 2012 | 08:27 PM
  #65
a-low's Avatar
Thanks for the info tjabo. Sux to here about precision turbos i hear their turbos are pretty badass but customer service blows. If the gt45 didnt have that small compressor id be all over it.
Old Sep 24, 2012 | 10:50 AM
  #66
T76s10's Avatar
Hey sarg, their isn't a link i emailed Chad to get specs and pricing. If you look on Ebay under on3's 4.0 mustang turbo kit they have some specs of their 61mm
Old Sep 24, 2012 | 11:20 AM
  #67
Sarg's Avatar
Gotcha. Wonder what size the turbine wheels are. Sounds like it might be a tad smaller than a 35r. 525 hp max.
Old Sep 24, 2012 | 08:53 PM
  #68
T76s10's Avatar
Their turbines are 65mm like the rest. I think they'll work out perfect
Old Sep 26, 2012 | 03:47 AM
  #69
smokeshow's Avatar
I just put twin T70s on my L76 and its a laggy bitch...I was coming from an S480 1.32AR with a quick spool valve, now am running the 70s with the .68AR housings. I used to be able to foot brake whatever boost I wanted fairly quickly, but now after 4-5 seconds it'll only hit around 4-5psi. This is with 4700ft DA, but still noticeably slower spool than the 80mm. May have to grab some of those on3 61mm turbos.
Old Oct 31, 2012 | 08:18 PM
  #70
99VetteFRC's Avatar
I've spent a whole year building my 4.8 tt project and used the Ebay t70's. The turbos are so laggy, I hate them. I can't get them to make over 6psi with 8psi springs. They don't start to spool untill 3000 rpm and doesn't make full boost untill almost 4000rpm. It went a best pass 13.60 @ 103 with a 2.22 60'. HELP!!!
Old Oct 31, 2012 | 08:46 PM
  #71
Sarg's Avatar
LMAO that is not that laggy at all for 70mm turbos. Get a good stall converter and a 2 step. And quite honestly the springs are just a ball park, they are not always exact.
Old Oct 31, 2012 | 08:50 PM
  #72
silver_82's Avatar
Whats the afr and timing? What fuel? Intercooled?
Old Oct 31, 2012 | 09:07 PM
  #73
99VetteFRC's Avatar
I have FMIC and the afr stays between 11.2- 11.5 and I tried timing all over the board. I tried timing it like a N/A car till about 3400 then went to 21* at one point. It's losing so much on the bottom end.
I also run 93 octane and have a 3000 stall.
Old Oct 31, 2012 | 09:28 PM
  #74
ZNix's Avatar
Do you know what the actual stall is? A turbo stall is completely different than an N/A stall. Go brake boost the car till you see 0-1PSI of boost. That will give you the stall RPM. I am willing to bet it is too tight. Also.. Get a boost controller and add some boost. 6# isn't going to get you anywhere..
Zack
Old Oct 31, 2012 | 10:54 PM
  #75
LilJohn's Avatar
Whats the CAM look like in these laggy motors???
4.10 rear gear... really???? You are letting the engine have SOOO much mechanical advantage here that the motor never loads the turbos up to make them work!!!! Get a 3.42 in the thing....
Get the air fuel up in the 12.3-12.5 range till it starts making 2-3 psi then then bring it down to 11.5. Leave ALL the timing in it till 5-6.... hell on alot of tunes i dont start pulling timing till 8!
9 times outta 10... lag isnt the TURBOS FAULT....its in the tune and setup!
Old Nov 1, 2012 | 12:55 AM
  #76
95bowtie's Avatar
Complete truth ^^
Old Nov 1, 2012 | 05:02 AM
  #77
99VetteFRC's Avatar
I had 3.08 gears in it and it was way worse. It does have a stock cam and LS6 springs. I don't wanna go to big on the converter, it is a pure street car, and it flashes at 3000 but if I powerbrake it it starts driving through the brakes at 2200 or so. I figured my SETUP was bad, thought the turbos were just to big for a stock 4.8. When idling they stop spinning completly.
Old Nov 1, 2012 | 06:00 AM
  #78
Sarg's Avatar
Well, they ARE 70mm turbos. You can't expect magic out of them and the turbine tech is probably not exactly the latest greatest compared to a Borg or Garret. If you were looking for full spool by 3000 rpms then a pair of T3 sized turbos or smaller T4 turbos would have been a better bet and something in the 56-62mm range.
Some things to check and try in addition to the excellent advice from LilJohn. Make sure there are no exhaust leaks. Wrap any piping leading to the turbos. Both of those will aid in spool up. But you can only expect so much from those turbos. If you want them to spool up a little quicker try putting a little stiffer spring in there to make sure the gates are not cracking open too early.
Old Nov 1, 2012 | 07:03 AM
  #79
LilJohn's Avatar
Until you are prepared to put a cam in that motor... it will never do what you want it to do. Plain and simple. Had you left the gear alone and done a cam and springs you would be alot happier right now.
The stock cam just does not have the valve events anywhere close to proper to drive those turbos.
I tune a 331 sbf with a 218/218 @.050 hydraulic roller that does the same thing. At idle you can reach in and grab the compressor nut on the S480 and stop it completely.
Proper cam and springs, 400 more on the stall, and back to a more proper gear.... youd be much happier with your decision to go twins.
Old Nov 1, 2012 | 11:24 AM
  #80
99VetteFRC's Avatar
I was looking into LS6 cam(already have the springs) but can't nfind anything I can afford. Trade and barter system here. My stepfather's boss was supposed to give me a stock LS1 cam but I haven't heard anything about that yet. I don't wanna go too big on the converter, it would make the thing a pig to drive on the street with a th350.
