Tired of running so slow.
Old Sep 25, 2012 | 08:34 AM
RacerXLs1's Avatar
No offense. But i think your wasting your time. I no you want more power but you need some suspension work or swap that thing to a auto. I understand you only go once or twice a year but somthing is wrong. What do you have for lower control arms and torque arm?
Old Sep 25, 2012 | 08:35 AM
RacerXLs1's Avatar
My buddy had a procharged camaro six speed wi
Old Sep 25, 2012 | 12:09 PM
4kiro's Avatar
Stock lowers and torque arm. Car is lowered and I don't have the Relocation brackets. Plan on a 12bolt with BMR torque arm, control arms and relocation brackets this winter. Might have to do more suspension stuff before the next trip to the track. Gonna go ahead and order the head studs and get this build going.
Old Sep 25, 2012 | 12:39 PM
91sonomast's Avatar
Something is not right. My 98 Dakota with a whopping 230hp @ the crank will get mid 15's in the quarter.
Old Sep 25, 2012 | 01:19 PM
taws6m6's Avatar
What's the tune look like other than a/f? Timing?
Old Sep 25, 2012 | 01:37 PM
Fall Line's Avatar
Do you have a shift light?
Old Sep 25, 2012 | 01:49 PM
KILLERxSS's Avatar
Could be elevation mine did a 13.8 at 4-5 psi .....granted with horrible tires and slow start to prevent spinning but my mph were higher then that. 5.0s do 14s over here too lol
Old Sep 25, 2012 | 02:58 PM
RacerXLs1's Avatar
The only reason im questionin is my buddys car with the same power would go super low 12z high 11s on street tires. Bone stock suspenison.
Old Sep 25, 2012 | 02:59 PM
RacerXLs1's Avatar
6 speed also
Old Sep 25, 2012 | 03:08 PM
KILLERxSS's Avatar
Dam I wish I was at sea level -__-
Old Sep 25, 2012 | 07:18 PM
bwkmaro's Avatar
i pull 13.2 at 100 with a 1.8 60' with 290whp v6..... the hp is NOT the prob post a pic of you slip please id like to see it a video would be nice to
Old Sep 25, 2012 | 07:20 PM
  #32
KILLERxSS's Avatar
^^^ dam a v6 ?? Haha pro
Old Sep 25, 2012 | 07:50 PM
  #33
I8UR4RD's Avatar
I was a 12.2 spinning with a bad 60 foot on a cam bolt on car making 393. it was prob high 11's. I am now procharged but have no runs on boost yet.
however..... if that car is on 10lbs....something is up. it should be in the mid to high 11's
Id ditch the zr1's and get a stock 17'' wheel. ditch the nt555r and get either a nt05r or a MT
its also a 6 speed.
it sounds like a mix between the suspension not handling that power and possibly need to make some shifting adjustments.
this guy right here has it down pat.
Old Sep 25, 2012 | 09:19 PM
  #34
hardbodeez's Avatar
Originally Posted by josepy121380
The one and only time i ran my car at the track i cut a 11.8 on the 6 speed with the p1sc at 8lbs. 121mph.
This is only on 8lbs, and he is at 121mph.
What you should say, is, the hp isn't the only problem.
I don't care what your car made on the dyno, because it's obviously not reflecting in the mph. Did the tuner give you a good dyno# then richen AF and back off timing to keep it safe? Is it pulling timing during the runs? Hard to say without a log, but bwkmaro is right as a time slip would be nice.
Old Sep 25, 2012 | 09:39 PM
  #35
6.0mustang's Avatar
get slicks, until you do suspension research that will help you hook on a radial. get a 2 step. leave on bboost. bang gears like a mad man or go auto. 1200hp wouldnt help you at this point.
Old Sep 25, 2012 | 09:57 PM
  #36
4kiro's Avatar
Well I don't know what the timing is at, I bought the car this way. Stock LS1 with a F1a procharger. I have a video and slip that I will post tomorrow. Hopefully I find out that it's my driving skills. First time I went to the track I was seeing about 6 psi. I ran two 12.70. One at 110 mph and the second at 116. I have a old oil filter i am
going to cut up and see if I find any metal. Thanks for all the suggestions.
Old Sep 26, 2012 | 02:30 AM
  #37
93camaro_zzz's Avatar
Here's what you need to do.
-Used set of LCAs off this site
-Used set of 15x8 Weld or Racestar wheels
-275/60/15 MT DRs
-Remove front sway bar
-Used torque arm off this site
Then.... Have fun with 11's.
Old Sep 26, 2012 | 03:41 AM
  #38
winters97gt's Avatar
Something has to be wrong. At 10psi on a stock LS3, no headers, stock heads, stock cam, I ran 10.5@136mph. My race weight was 3500 pounds, full street trim. I've seen fbodys go just slightly slower at around 130mph with supporting mods. Autos might ET better, but something is wrong.
Old Sep 26, 2012 | 11:58 PM
  #39
hardbodeez's Avatar
Originally Posted by 4kiro
I have have a slip on me right now. On about 10 psi I ran a 13.01 at 113 mph. 2.15 sixty foot. I was using Nitto 555r 17 on stock ZR1s wheels. After this mods I dont see much of an improvement then the M6 is coming out.
The numbers from these posts aren't matching. Honestly you're not taking anyone's advice if the only thing you are doing to trace this problem is cutting up your filter. I have no idea why you don't want to listen to ppl trying to help you, but whatever. Good luck.
Old Sep 27, 2012 | 12:38 AM
  #40
PRAY HRD's Avatar
Originally Posted by TurboMark8
510wheel should get u into the 11's no prob
agreed on it being no problem, or shouldn't be. 487rwhp/440 tq n/a last year got me the numbers in my sig....10.37 @ 128 and a 1.37 short time with a 4l60, 3600 stall & 3.70 gear @ 3400rw. something is wrong and it's more than just your short time. post a vid if you can and maybe that will reveal more of the big picture.
