Tick Performance Blower&Turbo Cams!!!
#41
Forgot to mention I will be using stock ls6 intake and stock 317 heads don't know if it matters?
What's the diffrenece between the two you posted?
Am I gonna have any clearance issues with the cam and stock parts?
Any idle vids?
Thanks a lot looks like I will be contacting you shortly to pick up a package
Any idle vids?
#42
Any idle vids?
Any idle vids?
The 236/238 uses a slightly slower lobe than the 237/238 does. I did that on purpose so if I had a customer that had the same valve event requirements as another customer, but had heavier valves or rockers I could default to the slower intake lobe. Exhaust lobe is the same on both cams.
You shouldn't have any clearance problems, but I would measure to be 100% sure. If you do it will be on the exhaust side.
If you would like a sure fire fit for your stock components I can custom grind you a cam that will fit for sure.
I always tell people to measure if they are unsure if the cam will clear with adequate clearance.
#45
Hey Martin,
What one of your cams would you recommend for the following?
99 Formula a4
Aps twin turbo
Forged 346
317 heads
3600 stall
3.23 gear
Not a daily driver.
Thanks.
99 Formula a4
Aps twin turbo
Forged 346
317 heads
3600 stall
3.23 gear
Not a daily driver.
Thanks.
