Boost/Vac FPR double check please
Also using hptuners. Sounds like I need to copy the 0kpa value from the injector flow rate vs kpa table and paste this across all cells. Can anyone confirm?
Thanks!
If you have applied intake vacuum to the regulator then fuel pressure will drop at idle ( assuming there is vacuum in the intake )
it may not drop the 9-10psi you expect, but it should be pretty close to 1:1
Fuel pressure should rise as you stab the throttle and there is less vac in the intake, then it should fall again on the overrun when there is more vac in the intake, then stabilise again at idle.
But Mityvac would be best.
Fuel pressure will track intake manifold pressure for as long as the signal line is attached.. That can either be up, or down.
Base pressure is referred to as such with no vac line connected so should always be constant assuming no other problems.
