TH400 or 4l80E for High HP Boost.. and gears
Old Oct 17, 2012 | 08:07 PM
zapp109's Avatar
Default TH400 or 4l80E for High HP Boost.. and gears
Yes yes i know its not in trans section but Im curious what you boost guys think, I wanted the RPM 4l80e since its a 90% street car and OD would be great but money is getting tight and i could really use the $4000 else where and not in just a trans. For a 800-900HP boost car do you guys think the TH400 will be OK for a street car with lets say a 3.08 gear? I wanted the car to be a highway monster. Fox Body....
Old Oct 17, 2012 | 08:24 PM
LS1NOVA's Avatar
If you really want a highway monster you will appreciate the overdrive even with high gears.
Old Oct 17, 2012 | 08:38 PM
LS1PUNK's Avatar
Im planning on doing the same thing eventually.
Extra gear with the ability of locking up the converter is why I want one.
Jakes Performance has a fully manual one that Im looking at.
Old Oct 17, 2012 | 09:39 PM
I8UR4RD's Avatar
bout to grab my jakes level 5. comes with a custom trans brake. basically built for 1500rwhp. overdrive and the gas mileage. long trips. itll come in handy. there are a few other reasons i looked into this and decided i dont want the th400. its basically the same trans, and does not weigh that much less. id find the link for it but eh.
Old Oct 17, 2012 | 10:16 PM
Stumped1215's Avatar
TH400 with a gear vendor? Just a suggestion as I dont see many people on the ls side running them.
Old Oct 17, 2012 | 10:55 PM
code4's Avatar
I have one of each in my two turbo cars. The 400 is on a 4th gen with 2.75 gears. I love everything about it except the non lockup converter. It's a low 9 sec car but drives nice. But the cruise control surges and rpm's climb when going up a grade etc.
The 4l80 is in a rat rod. It is tunable & I have it that once it locks up in OD it will pull any hill without unlocking or shifting. F'n love it, turbo just pulls that bitch right along at very low rpms. It has 3.00 gears.
Old Oct 17, 2012 | 11:33 PM
skinnies's Avatar
We've got 3:08, 2.73, etc gears in almost all of our street car turbo ls builds we do with th400's or powerglides. It works great, can cruise down highway still fine, and since making enough power can still 60ft fine.
Old Oct 17, 2012 | 11:47 PM
o2camaross's Avatar
Love my 400. Its lighter, cheaper, simpler and I love not having to worry about elecronic problems or tranny tuning. 3.42 gears here
Old Oct 18, 2012 | 02:21 AM
baggins's Avatar
What are your approximate cruising rpm's at say 70-75 mph with the non od trans'? With 2.73s or 3.08s?
Old Oct 18, 2012 | 06:28 AM
zapp109's Avatar
Seems like a split room, not making this easy for me fellas .. But keep it coming, I had a TH400 in my old notch with nitrous. Guess I had a bad converter it just felt like poo on highway. But that was with very little power compared to my new build.
Old Oct 18, 2012 | 08:08 AM
00Wildcat's Avatar
haven't ran mine yet but bought low mileage 03 4l80e (came with lq4 pullout) Jake's brake and manual controller $550, $75 used early od planetary, paid my trans guy $300 to put it all in, do the internal mods Jake recommended and put new frictions in. Plan to run trans with Holley Dominator but bought manual controller in case learning curve on trans tuning was steep
Old Oct 18, 2012 | 09:50 AM
RedRocketZ28's Avatar
I have a $200 craigslist special 4L80 in mine with a HD-2 and 2.73's in the rear. So far the trans has been working great. I was always used to a 6 speed car so it's nice cruising along at 70 at 1800 RPM's. I wanted the most DD friendly trans as I like to drive my cars.
68 SS's Avatar
I have the 80 with all the options Jake offers billet shafts front to back and all, spend the $$ once and be done with it for good. I am running a 4.10 rear gear.
Old Oct 18, 2012 | 09:54 AM
js2fst's Avatar
Skinnies how big of fuel cells are you running
Old Oct 18, 2012 | 10:21 AM
code4's Avatar
I am around 2100 at a little over 70 mph with my 2.75 & 28" tire if all is right. The 3k stall will let it go up if I am going up hill & like i said surges pretty bad when on cruise control unless it is totally flat road.
I got 25 mpg on the hot rod power tour on the highway. Drove it thousands & thousands of miles just to get to the start of HRPT.
Old Oct 18, 2012 | 11:19 AM
Danny's Avatar
I have a TH400 that will be going into my 1000whp build. I would love to have a 4L80E but the cost is what scares me away.
Old Oct 18, 2012 | 02:41 PM
MIGHTYMOUSE's Avatar
ive had both, also dont forget the 4l80 you can just put in D and none of this shift it yourself business.
Old Oct 18, 2012 | 02:44 PM
chiaj144's Avatar
I run a th400 with 3.08 gears on a 26" tire. At 2500rpm my gps says 72mph.
Old Oct 18, 2012 | 03:56 PM
skinnies's Avatar
Are you running a HUGE cam or what? It shouldn't be surging going up a hill, sounds like it needs a better tune! Especially with a non lockup converter.
Old Oct 18, 2012 | 04:56 PM
chiaj144's Avatar
My car would surge when I tried to run it too lean at cruise.
