Do I need meth with E85............18psi
Old Oct 21, 2012 | 09:42 PM
Cam72aro's Avatar
You set up the tune to where it only changes the fueling and timing when it sees the drop in inlet air temp. If it doesn't see the drop, ie meth failure, then it stays on the no meth fueling and timing.
Old Oct 21, 2012 | 10:14 PM
LS6427's Avatar
You mean the tune only changes when it sees a "rise" in IAT....?
Old Oct 21, 2012 | 10:21 PM
gsxr1k2's Avatar
Originally Posted by LS6427
Hell no...what?
No lag down low with a GT47-88?
Is it gonna make 1,000 RWHP pretty easily with my 390ci?
Hell no to meth........Seems the thread has taken a turn.
Old Oct 22, 2012 | 12:00 AM
fotoboy's Avatar
Iat can be as high as 140 before I'd worry. Remember the iat sensor is only reading the air before the e85. The e85 will cool the charge before it enters the chamber.
Old Oct 22, 2012 | 12:17 AM
LS6427's Avatar
I guess we'll just have to see how hot the IAT's are with the FMIC........if I can hit my RWHP goal without meth that would be great.
Old Oct 22, 2012 | 12:51 AM
fotoboy's Avatar
All the high hp cars up here only run e85. My car isn't with In ur goal but I saw 90 deg iat on a 78 deg day making 730 whp on e85.
Old Oct 22, 2012 | 01:59 AM
LS6427's Avatar
Cool, then its looking more like I'll be able to run without meth and make plenty of power to make me happy.
I'm making a water mist system to put in front of the FMIC. I push a button and 3 misters release water mist over the entire front surface area of the FMIC. I'm thinking that'll drop temps quite a bit. My car will be the test car for my little product. It'll use the windshield washer fluid tank......thats enough for about 3 hours of sustained use. The little pump is only 2 pounds. Just a little product me and a friend are gonna build and test. Maybe with a puller fan on the back of the FMIC that comes on with the water mist.
Old Oct 22, 2012 | 07:20 AM
Sarg's Avatar
Works well on Subarus. They have that same water mister built in from the factory.
Old Oct 22, 2012 | 08:10 AM
Cam72aro's Avatar
Meth drops the iat's. When the iat sensor sees the drop then you tune it to pull fuel and add timing. If the meth doesnt kick on then the iat's stay high and the fueling and timing isn't modified. I tune first on no meth, then in the iat modifers I configure it to add timing and pull fuel when the methanol drops the iat temp. Hope this helps. Also, with e85 you wont see the reduced iat's on the sensor, because the injectors are after it. You still have a cooler inlet temp at the intake valve, but there is no way to record it.
Old Oct 22, 2012 | 10:59 AM
Sales@Tick's Avatar
Do you have to have it? No, would it be nice to have it? Yes, it will only add more octane to the combustion charge which has never hurt anything.
I'd run at least a GT88 or GT91 with the 97mm turbine and I'd also look at the GT5018 with it's 98mm turbine. I also wouldn't be afraid of a S588.
Old Oct 22, 2012 | 12:17 PM
alexcoreas's Avatar
https://ls1tech.com/forums/showthrea...1#post16832111
Old Oct 22, 2012 | 12:19 PM
  #32
alexcoreas's Avatar
Damn! Sorry about posting. I.can't figure out how to delete on my mobile device
Old Oct 22, 2012 | 12:47 PM
  #33
N2OBaby's Avatar
Suggestion E-98 no Meth.
Old Oct 22, 2012 | 09:52 PM
  #34
LS6427's Avatar
Where do I buy that juice...?
Old Oct 23, 2012 | 01:33 PM
  #35
N2OBaby's Avatar
According to the GMHTP article KoolRay was running it exclusively.
Old Oct 23, 2012 | 03:33 PM
  #36
LS6427's Avatar
If its not sold at stations like E85, I can't do that. Too much of a pain. There's E85 stations all over my area.
Old Oct 24, 2012 | 08:50 AM
  #37
Sales@Tick's Avatar
You have to get E98 by the barrel.
By Brett Foote | 2026-06-04 05:00:17
