Same physical size turbo as 76gts
My set up consists of
10 to 1 370
LSA heads and ls3 intake
222/226 custom turbo cam on a 115+1
Up and forward headers. 1 3/4 primaries and 2 1/2 inch merge
3" downpipe but I can do a 3.5 inch out of the turbo to a 3" reducer if needed.
I saw that turbonetics has a mid framed T4 turbo. With a f1 75 mm turbine. Would that be better than what I have?
Any other suggestions are welcome.
http://turboneticsinc.com/store/inde...product_id=529
Hmm...well maybe I will have to alter my crossover some to get a t6 to fit. Hopefully the 76gts will just perform how I want and I won't have to worry about switching it out.
I say you best bet is to just spray it if you don't want a physically bigger turbo.
only thing bigger is the bearing housing and turbine housing physically
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
When I traded my 76gts for the PT88 from gimmeluvin I looked at them both and they were obviously the compressor cover, but the exhaust is a fair bit larger. That little 76 looked like it belonged on a honda compared to the pt88 even though the only difference was the exhaust side.
