lq4 Turbo Build HELP
I know there is alot of thread like this, but i need the help bad. I have done a ton of reading and i have learn a few things. Alot to learn so i rather ask the gurus here... So here it goes:
What i want out of my car
*Power Goals: 5-600hp of stock motor till i get my LME 408 sometime next year
*It will DD but will see track ones in a full moon, dont car about how it rids
What I have so far:
LQ4 out of 04 2500
fast 78/78 intake & tb
317 heads
arp head studs
ls9 head gaskets
cxracing intercooler 31x12x4
i know its not much but im just starting haha
What turbo should i get i was thinking a s475
what injectors, blowoff vavle, wastegate,cam, fuel pumps shoud i get. Will my stock fuel lines handle my hp goals........ Any info helps alot and please feel free to and and info im missing and parts im missing. Im doing all the building myself since im a welder i can fab up my own turbo kit.
What I have so far:
LQ4 out of 04 2500
317 heads
arp head studs
ls9 head gaskets
this has been covered time and time again. More infomation would help people help you, such as year/make? Im no expert by any means, but there are MULTIPLE 6.0 turbo builds you can get ideas from
ok well its going into a 2000 camaro... i dont understand the whole A/R Ratio's on the s475 on the website there r 2 one is 1.10a/r and the other is 1.32a/r and the prices on each are not even close.. So anyone want to throw any info that can help me out with
what transmission are you running? once you post some more specifics I would be more than glad to throw a few suggestions/opinions your way as I am currently building a 6.0/4l80 combo
It will have a built 4l60e rated up to 600hp with a yank ss4000... Do u think it will b a good setup for my build.. Since I already have it. I have 4.10 gears but will plan to down the gears to maybe 342 or something lower.
