***Important Oil information for ANYONE****
thats some thick stuff haha
if its really cold you could always pull the ign/fuel fuses real quick and turn it over a few times to get things a lil more oiled up before you actually start it.
Ive done many,many cam installs in ls motors since 00. Still havent had a lifter or cam failure. Also use 20w50 in the turbo builds ive put out.
Good info links in this thread
This thread has me thinking of buying a quart of common oils and burning 3 samples of each to see how they stack up against each other.
My local machine shop recommended to use only it in my dads flat tappet cam BBC so I'm guessing it has enough. Hey recommended and sold him a zddp additive also. I'm wondering if just running rotella is good enough for a regular ole ls1 with a turbo?
I tried out a bunch of different oils a few years ago, and I found Redline Racing oil to have the least reduction in oil pressure of anything I tried. The 50wt and even the 60wt seemed to flow very well when cold, and maintained the most oil pressure after a bunch of beating on the sucker and making a lot of boost.
The Rotella 15w40 mineral oil was scary as far as how much oil pressure it lost, and IIRC that is what I had in one time when I lost a rod bearing. Could be coincidence, but I didn't like the situation.
I liked the way the internals looked after running VR1, but that **** is thick as hell when it's cold, so that always concerned me a little bit...
Anyway, just food for thought.
Bottom line though, if I'm running a highly stressed journal bearing turbo, I want high quality synthetic in the crankcase just because they handle the heat so much better and can still flow when cold. Unfortunately, my next project is a BMW 540i that holds 8 quarts BEFORE adding the lines to the rear-mount turbo. It's gonna be an expensive fill! Haha...
I would switch, I made the switch a while back to 0w-40, just didn't realize the zddp levels had dropped off so much over the years.
EDIT: it's a lot cheaper than the $9 a quart I pay now as well
