Comp turbo or PT7675
I "think" that the PT makes more power due to a better flowing turbine. Call comp & tell them that you have a 370 ls & see what they recommend. They have been been working on a couple of similar set ups lately with too much back pressure.
Although I have not seen any back pressure tests with the pt on a 370. I went with twins from them so that I could package more turbine with the space I have available.
is direct with Comp to offer you great pricing!Contact me if interested in a Comp!
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Comp can make you a turbo which uses the CT43 compressor cover, CT5 center section with an 88mm turbine or GT50 style turbine and the 80mm billet wheel, that is one badass turbo. Its a little longer than a regular CT43 but physically the same diameter.
Also when using the regular CT43 chassis the cast 7879 or cast/billet 7479 are the only two good options. the 80mm compressors move WAY too much air for the the turbine to handle, this keeps the shaft speed down and makes the backpressure go up dramatically
Comp also has a 1.52 divided turbine housing availible that makes a HUGE difference
