88mm single turbo build
Old Dec 11, 2012 | 07:46 AM
9sectruck's Avatar
more pics.
tried some 200 on the front, they may work but looking a lil light
Old Dec 21, 2012 | 04:03 PM
RacerXLs1's Avatar
Is this running yet? Lol bump
Old Dec 21, 2012 | 04:29 PM
9sectruck's Avatar
GETTING CLOSE.
got the interior back in last weekend, just the lil bullshit stuff left to do
Old Dec 21, 2012 | 11:48 PM
Mightymike2000ss's Avatar
From: Home town Clive,IA current town FORT BENNING GEORGIA
What's the final cubes on your motor? Which rockers you running?
Old Dec 22, 2012 | 07:21 AM
Taubr Unit's Avatar
Looks pretty badass! The 325's look great under there
Old Dec 22, 2012 | 08:55 AM
Camaro9969's Avatar
Like that stance what springs you have in the front??? And you have any pictures of the inner rear fenders cut out?
Old Dec 22, 2012 | 09:57 AM
9sectruck's Avatar
STOCK 5.3 for now, with some very highly hand ported 241.
I tore the engine down honed the cylinders, gap the rings to .023, put king bearings in it(I HAVE ALWAYS WANTED TO SEE HOW THE KING BEARINGS WOULD PERFORM)
stock rockers, 06 ls2 cam, prc 660 springs, harden push rods, ls9 gaskets, ebay head studs and arp main studs, I also did sum mods to the block for the thrust bearing for pressurized oil, (TRIAL AND ERROR ON THIS) (we will see)
I have been a die hard procharger guy for about 10years and this is my first turbo build, if this one pops $1k no big deal, with my forged engine the crank alone cost 1800 i would be a little upset if it popped right away.
Old Dec 22, 2012 | 10:39 AM
9sectruck's Avatar
yes the 325 look sexy as hell on the car.
I have three set sets of tires and wheels 325 50, 275 60, and a set of 26 10.5 hossier slicks, going to get the car to work on the radials then set the car up for slicks
the slicks look the best on the car as in they do not look like a balloon on the back of the car, the radials came with wheels so ill burn them up testing the car
Old Dec 22, 2012 | 11:19 AM
9sectruck's Avatar
those are 200 14" the shock was fully compressed in that pic, I did not have the spring crank all the way up in that pic, if it was a drag only car, may be able to crank the 200lbs springs up enough to get them to work but no for a street car
Old Dec 22, 2012 | 10:44 PM
80gus's Avatar
how do oyu find them hood catch's? i was going to order a set myself
Old Dec 23, 2012 | 10:49 PM
9sectruck's Avatar
I found mine on ebay.
Old Dec 28, 2012 | 08:54 AM
  #32
9sectruck's Avatar
got the meth pump and the big stand alone fuel pump all wired up last night, then got the meth tank mounted, I think it turned out pretty nice once all the covers are in place you cant see it at all..PS dont mind the chicken scratch welds in the pic I guess the Original Builder was trying to learn how to weld
Old Jan 7, 2013 | 10:07 AM
  #33
9sectruck's Avatar
WELL IT RUNS
tried to blow my leg off on the first start, but after that fired right up, it was 10.3afr in this vid lil fat, try to get most of it buttoned up next weekend
http://i842.photobucket.com/albums/z...9344CD31F0.mp4
RUNNING
http://i842.photobucket.com/albums/z...5F92B0BBF7.mp4
Old Jan 7, 2013 | 01:48 PM
  #34
M2W-GTO's Avatar
Smooth move on the first try. Second video still sounds nasty... What's the lsa for that cam?
Old Jan 7, 2013 | 02:06 PM
  #35
Reject's Avatar
i cant get the videos to work. i've tried it on Firefox Internet Exploder Google Chrome
Old Jan 7, 2013 | 05:05 PM
  #36
kylemm1002's Avatar
Can you post up some pics of how u mounte the hood pins and how they look with the hood closed?
Great build man. Can't wait to start my turbo build.
Good luck getting it ironed out!
Old Jan 7, 2013 | 08:33 PM
  #37
9sectruck's Avatar
will get pics 2maro of the hood,
a buddy uploaded the vids, my computer has trouble loading them for some reason some times as well.
internet explore seems to work the best for the vids.
stock ls2 cam...... I still have no stock parts yet?
Old Jan 8, 2013 | 04:14 AM
  #38
93camaro_zzz's Avatar
Lovin the build man! Just a couple of questions:
Did your alternator end up fitting in the stock location with the 3 bolt flanges cut off of the manifolds?
Did you have any pics of the cuts you made to the inner rear fenders? I am looking to run the 325 mickeys as well, and would like to see all that was done by you.
Good luck on finishing it up, I am subscrubed!
Old Jan 8, 2013 | 04:31 AM
  #39
BOBS99SS's Avatar
Captain Double Post
Nice build,street vids asap,you do some good work
Old Jan 8, 2013 | 07:30 AM
  #40
9sectruck's Avatar
yes the alternator does fit in stock location with the vband welded to the stock 6.0 manifolds.
you need a big hammer!!!!
you need to cut the factory bump stop mounts off and cut the lower front part of the inner finder off basically right under the floor pan of the car.
I will get some pics tonight for the guys asking for them.
I have the right offset for the narrowed rear end and with them tucked as close to the inner fender as possible they will hit the outer finder lips if you dont make new bump stops.
I have coil overs on the rear with stops built on to the shocks
