Turbonetics NEW 7675 and 7875 Turbos AVAILABLE through Huron Speed!
#202
Patiently awaiting their turbos. I have quite a few tracking numbers from Turbonetics I need to get into contact with them on so I can disperse them. With that said, many turbos have already shipped out last week, and more are continuing to ship each day. As soon as I have confirmation on which tracking number is who's when I can contact them after the holiday, I will certainly give everyone their tracking information as soon as I possibly can!
Thanks for being patient everyone, you should all have your turbos in hand very shortly! ![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Jon
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Jon
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
#203
One just arrived! As you can see, it is a little cold here in Michigan!
New T-series 7875 next to a Hurricane Series
![](http://i833.photobucket.com/albums/zz253/Oh-Check/9D8D9D45-96D1-4B74-869F-C99DC0589A7D-2323-00000276F15932B3.jpg)
![](http://i833.photobucket.com/albums/zz253/Oh-Check/AF9601A4-0B99-4877-A498-493E3908C252-2323-0000027704E5714D.jpg)
![](http://i833.photobucket.com/albums/zz253/Oh-Check/983CC08B-E840-43E5-8EDA-342B0B6755E6-2323-00000276FACA136D.jpg)
__________________
#208
LS1TECH & Trucks Sponsor
It's true, they DO exist! Mine arrived today after they tried Monday and we were closed. Thanks superman ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![](http://i77.photobucket.com/albums/j68/z_driver1/SDPC/IMG_20121226_154811_zps3c01b5e2.jpg)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3451_2.gif)
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
#210
Just curious. What is that hole next to the turbonetics t used for? Ive been around big rig turbo diesels since I was sixteen and a majority of our turbos do not have that. Those that do is used to a solenoid to close the exhaust so the turbo will not over boost. Man the more I keep reading about turbo gasoline its incredible. Similar set ups but used for completely different reasons.
#211
Its used for boost control. Many detriot and cummins have it too.
Those .96 ex housings are getting a little tight.. Wouldnt be much material left?
Be interesting to see when these start to choke.
Pic with the covers off?
Where are these made?
The comp cover bolts and backing plate tabs stick out a long way whys that?
Sorry for all the questions, just genuine interest.
#213
#214
These are made by Turbonetics in California.
Unsure what you mean by the backing tabs. If you are looking at the comparison picture and looking at the Hurricane turbo, that would be because they are loose as I was using that turbo for mock up (one of the twins on our car)
__________________
#216
I know .96 is an A/R ratio not a thickness. Im talking about the amount of metal thats been machined from the housing to fit the 75mm wheel. Ive done a lot of turbcharger machining in my time and sometimes some wheel/housing combos come mighty close to paper thin.
In regards to the T series comp cover bolts and the tabs the hold the comp cover onto the backing plate, your saying they are just loose? And thats why they apear to stick out a long way? Ok.
#217
#218
#219
Ah, I got ya. I was assuming these are all new turbine housings made specifically for the 75mm wheel, no?
#220
__________________
