Turbonetics NEW 7675 and 7875 Turbos AVAILABLE through Huron Speed!
Old 01-14-2013, 01:35 PM
  #301
88blackiroc's Avatar
Originally Posted by 1nasty86
do i hear a free charitable donation?
Lol gonna shoot for another turbo 5.3 or stick with the ls2 this time around?
Old 01-14-2013, 02:37 PM
  #302
svg210's Avatar
Has anyone tried clocking theirs? I tried to loosem the four bolts and tnetics put a blue paste on the hex heads. Or am I aiming for the wrong bolts?
Old 01-14-2013, 02:40 PM
  #303
LS1Tech Sponsor
Superman09's Avatar
You have to loosen all of the bolts of what you are clocking. I would loosen up every bolt so you can clock all of the components to where you need them and then tighten them back up.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 01-14-2013, 03:36 PM
  #304
Which four bolts?! I think it's more like 5-6. And none of mine has any blue paste.
On the compressor side you loosen the bolts which hold the brackets on and the turbine side is basically the same... except no brackets. And you really only need to brake them from being tight and it should spin. At least mine did
Old 01-14-2013, 03:38 PM
  #305
LS1Tech Sponsor
Superman09's Avatar
__________________
Old 01-14-2013, 04:16 PM
  #306
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
I didn't have any blue paste either. The compressor cover bolts are clean and the exhaust bolts have nasty gold anti-seize on them. All loosened off and it clocks easily.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 01-14-2013, 04:23 PM
  #307
Hopefully he didn't loosen center bolts. I was told you'd need to rebalance it
Old 01-14-2013, 04:44 PM
  #308
Those do have blue paste on em, and there are 4:
__________________
Old 01-14-2013, 05:30 PM
  #309
Oh boy.
I see two turbos?? Big plans I hope
Old 01-14-2013, 06:05 PM
  #310
svg210's Avatar
Oh heavens no, when the time came I was going to post a picture question lol I think I got it know. If I want to turn the compressor side id have to lossen all those bolts behind it. thank you guys I finally got. It!
Old 01-14-2013, 06:10 PM
  #311
LS1Tech Sponsor
Superman09's Avatar
Oh boy.
Just two?
__________________
  #312
LS1Tech Sponsor
Superman09's Avatar
Good deal, let me know if you have any other questions!
Jon
__________________
Old 01-14-2013, 10:06 PM
  #313
Originally Posted by Superman09
Just two?
Lmao. Shoot, 3 more and you'll have the worlds first 24-charged trans am!
3 turbos per cylinder... Haaaaa
As impossible as it sounds, could you even imagine nightmare for piping, lines, etc.?
Old 01-14-2013, 10:07 PM
  #314
LS1Tech Sponsor
Superman09's Avatar
__________________
Old 01-15-2013, 01:46 PM
  #315
laytoncamaroz28's Avatar
Well I got my 78/75 .96 on this weekend and I don't have dyno numbers but I have 6 speed and I start building boost and get to full boost at least 800 rmp sooner verse my ol 78/68 1.15. and at full throttle I'm at 14 psi instead of 10-11 with no change to the wastegate. I had to turn it back down. So I know she has less back pressure. Thanks again huron
Old 01-15-2013, 01:47 PM
  #316
LS1Tech Sponsor
Superman09's Avatar
My pleasure, glad you are enjoying it!
Let me know if you ever need anything else Layton!
Jon
__________________
Old 01-16-2013, 08:45 AM
  #317
LS1Tech Sponsor
Superman09's Avatar
I usually always try to have these in stock to prevent waiting on the build time, one of each! If you need one let me know!
Billet 7675 .96 a/r
Billet 7675 1.15 ar
Cast 7875 .96 a/r
Cast 7875 1.15 a/r
__________________
Old 01-16-2013, 09:19 AM
  #318
regblkss's Avatar
Any word on the h.p. difference yet?
Old 01-16-2013, 09:25 AM
  #319
LS1Tech Sponsor
Superman09's Avatar
My rep has not gotten me that info yet. Soon as I have it I will post it up!
__________________
Old 01-17-2013, 01:09 PM
  #320
LS1Tech Sponsor
Superman09's Avatar
Cast 76 - 910hp
Cast 78 - 920hp
Billet 76 - 1000hp
Jon
__________________
Quick Reply: Turbonetics NEW 7675 and 7875 Turbos AVAILABLE through Huron Speed!
