Turbonetics NEW 7675 and 7875 Turbos AVAILABLE through Huron Speed!
#322
crank, they have no way to calculate for every person's different drivetrain set-up!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
#323
I am in no way beating you down or turbonetics because I love they went with a 75 turbine finally but are these numbers any chance to be way underestimated??? I am just throwing this out there but isnt the precision 7675 rated at 1150 for cast and 1250 for billet? I would have imagined these would have to be close to that? I am certain they are cheaper and built for longevity though!! please dont think this was a bash...I just would like to understand how this is
#324
In any event, in price comparison as well as in customer service, you can't beat these new Turbonetics!
Jon
__________________
#325
I think those numbers are close. 1000fwhp would be around 850 at the tyres.
Didnt skinnies 7675 billet pt make 850rwhp on 24psi?
I think the numbers are close.
No point exagerating, better to be conservative l say.
Has someone been on the rollers yet?
#326
Not that I am aware of. I know a few are enjoying them on the street where they don't have to deal with this snow stuff, but I haven't heard from anyone being on a dyno yet. We are working on getting our car finished up with a new kit fabbed that will allow very quick and easy access to swap turbos and plan on getting it on the dyno to back to back to back test a few different turbos!
__________________
#327
The day we do those tests is probably going to be the funnest day in huron speed history! cant wait
-Casey
-Casey
__________________
YOUR SOURCE FOR ALL THINGS TURBO!
CASEY@HURONSPEED.COM
TWITTER @HURONSPEED
TWITTER @HURONSPEED
#328
We are going to use a lot of gauges and cameras to monitor back press, boost, etc
__________________
#330
I am not sure on the rating for the T-series 7668, but it would be below what the 7675 could do. I would bet these are under-estimated preliminary numbers however for the t-series 75's
__________________
#332
We are hoping to do this in the next couple months! I have 4 T6 kits to build first, then a new T4 kit to use for testing as I need the turbos in a very easy to access and swap location, as well as get the car finished up and finalized so we can monitor everything as well!
__________________
#333
I will have the following turbos IN STOCK this week. This means ZERO wait time to build them. Order them direct from Huron Speed and we will ship to you same/next day depending on time of time!
BILLET wheel 7675 .96 a/r
BILLET wheel 7675 1.15 a/r
Cast wheel 7875 1.15 a/r
Hurricane Benita TC78 1.15 a/r
Jon
Jon
__________________
#335
Thanks!
#336
Martin and Jon, would the 7875 with the 1.15 AR be better in my setup over the .96 AR? I don't fully understand how the divided vs. undivided flange changes things. Would it matter that my current hot side flange is open/undivided? Think I will have any trouble hitting 700+ rwhp with my current setup with a 7875? FWIW I made 606/570 with the on3 on 14 lbs unlocked. Will be turning it up to 18 or so this spring with the new turbo. Also, would I benefit at all from running a different cam than the TU1?
Thanks!
Thanks!
Jon
__________________
#338
I have these in stock as well, no wait or build time!
Jon
__________________
#339
Thanks!
Thanks!
