Turbonetics NEW 7675 and 7875 Turbos AVAILABLE through Huron Speed!
#401
#403
Nice to see another lq4 turbo Iowa boy! lol Redrocket. Do me a huge favor. Swing up to Cedar Rapids and give me a ride. That way I know what to expect. lol
Great to see vids are starting to come in and some results!
#405
Thanks guys! Good updates and info in here
If anyone needs one of these, contact me!
Jon
Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
#406
Camaro is a ls1 317 heads 228r cam with a 6 speed, it spun to a 1.74 60 foot and went 10.98 @ 130 on 14psi 14 degrees of timing and was running out of fuel, Its been 1.64 before and should better that 60 foot yet, I see 10.60s on this boost yet
#407
I might take you up on that! I have friday off. lol Sad to say but Iv'e yet to ride in a fast turbo car.
How high have you spun it with the 7875? I know the .68 mm ones could choke a 6.0l.
#408
I had an on3 76mm with the 64.5 mm hotside and spun it to 6k. It actually ran very well and surprised me when it put down over 600 on 14 lbs. I have not done anything to the tune after swapping on the 7875. I am still spinning it to 6k but it feels a lot better. The tune still needs some final touches before I would call it "good". A guy in Kansas City has been doing the tuning and we haven't had a chance to meet up in person to get it dialed in. It is pretty darn close for just sending him logs over email though.
#410
__________________
#413
__________________
#414
We have a bunch more of these on order for stock to help keep build times down to nothing for you guys! Who needs one or any other Turbonetics unit for that matter?
__________________
#416
You will find your back-pressure will be decreased quite a bit, allowing you to make more power, as well as prevent the power from falling off in the upper RPM range! Being as you have a 370, you would really benefit from the 75mm turbine wheel in this compared to the 68mm turbine wheel in the TC78.... much more suited turbo for your engine size!
__________________
#417
we can always add to the order!
-Casey
__________________
YOUR SOURCE FOR ALL THINGS TURBO!
CASEY@HURONSPEED.COM
TWITTER @HURONSPEED
TWITTER @HURONSPEED
#418
https://ls1tech.com/forums/drag-raci...0s-friday.html
Went 7 tenths and 7mph faster with my new turbo and ptc converter on only 1psi more boost...
#420
Who else needs one!?
__________________
