Sloppy Mechanics guide (wire and fire ms1 and MSD6010 LSX)
Old 01-09-2013, 03:35 PM
  #101
Silver Sleeper's Avatar
yep...i want that logger...lol
Old 01-09-2013, 03:53 PM
  #102
Moderator
denmah's Avatar
Originally Posted by 3pedals
Can it log extra inputs beyond the EFI sensors?
I want 2 speed sensors and iat sensor, and maybe something else��
well there is a IAT sensor you can wire into the ms1 no issue, VSS i cant speak for..
there are lots of ways to do stuff with Megasquirt and i cant answer them all ahha. i would email support they would know for sure what you can and cant do.
i know there are usually spare inputs its just getting it to all work together and report the right data.
Old 01-09-2013, 03:58 PM
  #103
3pedals's Avatar
Ok just knowing there actually is some spare inputs is good!
Old 01-09-2013, 04:01 PM
  #104
Moderator
denmah's Avatar
yeah i cant wait to try it, but i have to use it on my friends cars since the fairmont is micro2 and its build to work with the MS1 chip running extra code.
Old 01-09-2013, 08:14 PM
  #105
tennerv8's Avatar
Any price on that datalogger as of yet?
Old 02-04-2013, 10:30 AM
  #106
tennerv8's Avatar
I just got my cam only LQ4 fired and running with help from Matt and this thread. I also used one of his turbo fuel tunes to fire it. It started right up. Even with my carbed timing map. I went right to tuning the fuel table. This setup works great.
Old 02-04-2013, 03:11 PM
  #107
Moderator
denmah's Avatar
i couldnt get it to work with the box i have, gotta check on some things with Mike @ AEA
i think he was gunna sell them for a little over 100 dollars
but just to clarify i havent tested it as working yet, so i cant help you if you buy one haha
Old 02-04-2013, 03:12 PM
  #108
Moderator
denmah's Avatar
this is awesome to hear! i love seeing the results!
that henry J recently went 12s on like 4psi using this setup! and one of my base tunes!
Old 02-20-2013, 12:55 PM
  #109
CROWN's Avatar
Nice nice nice!! Now what are you doing to control the trans? I have a 4l80 sitting in my garage but stuck because I really don't know what to do about controlling it...
Old 02-20-2013, 01:28 PM
  #110
Twin turbo c5's Avatar
Opti shift controller for the 4l80e will work great. That's what I have.
Old 02-20-2013, 02:11 PM
  #111
CROWN's Avatar
Is it 600 bucks like the tci and the other controllers ive looked at? Lol
Old 02-20-2013, 02:22 PM
  #112
Moderator
denmah's Avatar
yeah i believe it was around 550 with the harness and worked excellent..
AEA electronics (EFI source) will soon have a box that works like the MS3x, that can also do transmission control, not sure on a release date for this thing but he said he will be giving me one to test!
Old 03-01-2013, 01:17 PM
  #113
tta656's Avatar
bump for great info...
Old 07-27-2013, 08:32 PM
  #114
pitbull14218's Avatar
Bump great info, I'm a little confused i don't know if I missed something regarding wiring the injectors, you wire 12v to both banks and then the other wires on the injectors are all wired to a common in the megasquirt harness? I understand it grounds to complete the circuits to fire the injectors but it seemed like since all the commons are tied together wouldn't basically they fire the complete bank of injectors rather than individually when each cynlinder needed it? Unless I am confused and the commons for the injectors all have their own common to fire each individually in proper order... ?
Old 07-27-2013, 08:38 PM
  #115
ronnieforrester's Avatar
Correct.
It batch fires the injectors. 1 bank at a time.
So 4 fire then the other 4.
Old 07-27-2013, 08:39 PM
  #116
05_quick4door's Avatar
You can do trans control with the GPIO board and the mega shift kit.
Its under $300 and it can use the megasquirts engine sensors via can bus.
Old 07-27-2013, 09:47 PM
  #117
Originally Posted by ronnieforrester
Correct.
I never knew batch fire works like this and you can make that type of power safely with it, seems like you'd only need 6 more wires for squential fuel injection.
Old 07-27-2013, 09:58 PM
  #118
Moderator
denmah's Avatar
we have many cars making 600-700 on batch fuel a one in the 800 range
Old 07-28-2013, 09:55 AM
  #119
elkydragger's Avatar
I plan on making north of 1000hp with 160's batch fired on methanol. Should have it running by the end of summer. Do you really think that at 7000rpm+ the engine knows that is being batch fed or sequentially fed. I think it just wants fuel however it can get it.
Old 07-28-2013, 10:01 AM
  #120
Anyone ever try the semi sequential option vs untimed injection?
Quick Reply: Sloppy Mechanics guide (wire and fire ms1 and MSD6010 LSX)
