Lower static compression???
Old Nov 12, 2012 | 10:27 AM
Pat Burton's Avatar
Default Lower static compression???
Has any one stacked two Cometic MLS head gaskets together to lower their static compression? I know stacking sounds bad but the MLS gaskets are basically stacked gaskets anyways. I just didn't know if this has been tested on a boosted motor.
I am sitting at 10.0:1 and would love to be in the 9's or even 8's. I am getting my heads machined and going to gain about 5cc in the combustion chamber.
Old Nov 12, 2012 | 10:30 AM
LilJohn's Avatar
And exactly whats leading you to want to reduce the static compression?
Old Nov 12, 2012 | 10:41 AM
Pat Burton's Avatar
I want to lower my static compression so I can increase my volumetric efficiency and allow more boost without spark retard.
Old Nov 12, 2012 | 11:25 AM
ss1's Avatar
ss1
You can buy Cometics in almost any thickness you can imagine...within reason.
Old Nov 12, 2012 | 01:07 PM
dschmittie1's Avatar
I think stacking gaskets would be a bad idea. what fuel are you running and how much power are you looking for. My current motor is 10:1CR running E85 My last motor was 9.9:1CR on 93 and Meth.
Old Nov 12, 2012 | 01:49 PM
Pat Burton's Avatar
Just talked with a guy from cometics. He said they can do a 0.140 mls gasket. That will get me down into the 8.xx:1's. Right now im running a 10.0 with 11 lbs of boost. Im looking to build around 20lbs. Im hoping to get into the 8's with a 383. Anyone know of a better compression ratio to run from experience? Im running 110 shell unleaded gas.
Old Nov 12, 2012 | 01:51 PM
qqwqeqwrqwqtq's Avatar
Yes, leave it at 10.0-1 unless you're trying to reduce power and response.
Old Nov 12, 2012 | 02:20 PM
Pat Burton's Avatar
Hmmm. I've read different articles saying that you should run a lot lower CR's if you are trying add a lot of boost. So what is the optimal CR if the engine was at 10.0:1 at 11 lbs of boost when I am trying to get around 20 lbs. I was running a p600b and now I'm switching to an F1-R
Old Nov 12, 2012 | 02:31 PM
chasgiv3's Avatar
If you want to run big boost on pump gas then that's a different story. But at 110 I don't see an issue.
Old Nov 12, 2012 | 02:36 PM
I have seen 16 psi on my 10:1 385 cubic inch motor on E85 powered my 3400lb car to an 8.79@158 Saturday. I plan on turning it up closer to 20 psi next season
Old Nov 12, 2012 | 02:41 PM
Pat Burton's Avatar
What is your guys's IAT's? I'm not planning on running meth or nitrous. I run a water to air intercooler that keeps my IAT's below 100 degrees F
Old Nov 12, 2012 | 02:50 PM
No Meth and a cheap E-bay air to Air intercooler my IAT's are 140ish
Old Nov 12, 2012 | 02:59 PM
Pat Burton's Avatar
Damn thats not bad for air to air... Is 10.0 what many people run? I just want to be on the safe side because it isn't too hard to slap on a thicker head gasket. I was thinking about hittin 9.5:1 just to be safe. I guess there is more factors that just CR, like cam and valve events and keeping the heat down. So I guess I could stick with 10.0:1 and try and keep the air cool? Any other insight?
Old Nov 12, 2012 | 03:04 PM
I know of an Outlaw drag radial car that was a 427 with 10:1 CR and saw 40 psi
Old Nov 12, 2012 | 05:10 PM
jridenour31's Avatar
I don't see the point of this at all. 10-1 is fine for boost. Dynamic is more important anyway.
