post pics of your LS turbo mustangs/Notch engine bay setup
Truck intake will not clear without cowl hood/cut a hole, Or unless you make your own mounts to sit the motor lower in the bay but that. Lower motor/ oil pans lower and will get hit due to lower ground clearance.
I just order my Team Z yesterday and I called them before I ordered to verify that their unit will work with a truck pan. Hopefully I get it before or on friday so I can install it and check clearances.
But,check out Jim's Lexus build if you haven't seen it.
The Fairmont had a truck pan, with the stock k member, it hung lower that we would have liked but, holds alot of oil and didn't cost anything.
Mike's mustang has the f-body pan and an AJE k-member, we were a little worried about the stories of problems with that pan in a car that can sixty foot really good, but we had none of those problems even with alot of low 1.3s and a 1.27 sixty.
