ATI Crank Pulley backed out
Old Apr 12, 2004 | 09:33 PM
WHPLASH's Avatar
Default ATI Crank Pulley backed out
After getting on it today after the dyno-tune, I noticed the boost dying off after a couple of hard runs. Heard some clanking from the motor to find ou that the belt came off and the ATI crank pulley was wobbling. I remember some cutting down the crank bolt. We did use locktite on it. Any help is appreciated.
Thanks
Old Apr 12, 2004 | 10:44 PM
Irocss85's Avatar
also Id like to add that it was torqued as per instructions manual. how is everyone else doin it? is the blue bolt from ATI one time use only like the stock one?
chris
Old Apr 12, 2004 | 11:17 PM
BIGBOS's Avatar
I had this problem w/my 8 rib and COGS pulleys.....
I just put in a new fresh ATI bolt, its shorter than the bolts they had out before, I used red locktite on it, w/the supplied washer, cranked it to 37ftlbs, then turned the bolt 135 degrees from there, It was torquing well over 250ftlbs for a good 5 or 6 final last tugs, so its in there pretty good......
I had the bolt back out before on me, thats when I was using a used ATI crank bolt, so hopefully this will do the trick......
Old Apr 13, 2004 | 10:30 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You have to pin the crank pulley.
Old Apr 13, 2004 | 11:50 AM
Crunch's Avatar
ditto
http://www.atiperformanceproducts.co...s/pr/30402.htm
Old Apr 13, 2004 | 11:57 AM
PurEvl's Avatar
ya I pinned mine as well
Old Apr 13, 2004 | 11:58 AM
BIGBOS's Avatar
I found out that my crank is keyed, so it looks like I don't have to pin afterall....
Old Apr 13, 2004 | 01:52 PM
SSmokin 01's Avatar
Originally Posted by Crunch
If you don't want to have the pulley machined for a keyway. Magnuson has a kit that pins from the front and you don't need to remove the balancer. Bought mine from Tbyrne for $99.99 + s/h.
http://www.magnacharger.com/pdf/manual04.pdf
pg. 7-9
steps 18-27
Old Apr 15, 2004 | 09:31 PM
Jammer's Avatar
No need to spend $100. Get a drill bit and a screw and go to town.
