~Procharger budget build~
Bob ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Trust me, if your fuel pump starts to fail, and can't keep up, you're going to have a lot of problems.
Lonnie's dual intank setup is around $700. Sure, sounds expensive, but it's a simple plug and play setup and you don't have to worry about it.
The Racetronix harness comes equipped with an interface connector just after the relay (see product picture above). This connector in combination with an optionally supplied connector set (P/N PBIC) allows for easy plug and play addition of a pump booster / voltage amplifier such as the MSD or KB units. These voltage amplifiers / boosters will allow the Racetronix single in-tank pump system to support up to 700RWHP when run at 16-17 volts. This configuration offloads the excessive current draw placed on the factory wiring onto the heavy gauge Racetronix harness system. System diagnosis becomes easier by simply being able to unplug, isolate and bypass sections of the wiring system.
For what you will pay for a booster you can buy a second fuel pump and do it right.
First off I picked up a D1sc head unit for $1350 with 4k miles on it... I'm thinking of going with the cxracing intercooler kit off ebay for $475 and picking up a big red bypass valve for $300. Parts I plan to pick up from brute speed are- 6-rib J bracket $400, 6-rib pulley+bolt $200, crank pin kit $100, procharger+belt $200, air filter assembly $260. For fans I think I'll run a set of derale pusher fans for $300.
I only plan to run 5-7psi for awhile until I get the transmission built! I will post everything in order and add up the total below.
D1sc head unit-$1380
cxracing intercooler kit-$275
Proflow Bullet bypass-$125
8-rib J bracket-$225
8-rib Pulley+bolt-$65
crank pin kit-$100
ATI super damper-$435
Procharger pul+belt-$140
Deral pusher fans-$300
air filter+hat-$200
Ati boost gauge-$70
So total is at $3,320. Any parts you guys see that I'm leaving out? Any recommendations?
Do you see anything I'm missing Bob? Any recommendations?
16" spal part number VA33-AP71/LL-65A 30102082
9" spal part number 30100452
http://www.a1electric.com/Merchant2/..._Code=30102082
Yes I'm going to be getting the procharger sheet metal fan from you guys at brute speed.
