~Procharger budget build~
First off I picked up a D1sc head unit for $1380 with 3k miles on it... I'm thinking of going with the cxracing intercooler kit off ebay for $260. Parts I plan to pick up from brute speed are crank pin kit $100, air filter assembly $200, procharger fan shroud, ati boost gauge, and some other random parts. Planning to run a 16" spal fan to keep it cool.
I only plan to run 5-7psi for awhile until I get the transmission built! I will post everything in order and add up the total below.
D1sc head unit-$1380
cxracing intercooler kit-$275
Proflow Bullet bypass-$125
8-rib J bracket-$225
8-rib Pulley+bolt-$65
crank pin kit-$100
ATI super damper-$435
Procharger pulley+belt-$140
Spal fans + procharger fan mount-$280
air filter+hat-$200
Ati boost gauge-$70
Procharger Oil- $28
Sold SLP U/D pulley-$120
Sold Crank Pin kit-$30
Sold SLP Grille-$180?
Sold Stock fans-$60
So total is at $3,320. Any parts you guys see that I'm leaving out? Any recommendations?
Parts in bold have already been purchased. All that's left to buy is the cxracing intercooler!
D1SC's are good up to around 800rwhp depending on appication (auto vs stick, etc), which is quite fun on the street.
Glad to see you bit down on the 8 rib setup. you can look into the poor mans beltwrap method. some have had great success with it while others felt they wasted time. as long as your around 8-10 lbs it should hold pretty well. After that you may want to splurge and grab the aster or the SDCE bracket.
the hardest part of the install, to me was pinning the crank. Other than that it went smoothly. Label the bolts and where they go. bag em up. youll be done in 2-3 days even if its your first time as long as you have basic knowhow .
I highly doubt it will be any cheaper. But it will be quicker to install, less hassle, and youll make some great power. Blower all the way. Makes some neat noises too. Brandon's car is a stock bottom freak IMO
