stock 6.0L 8.81@161
Old 12-11-2012, 02:49 PM
  #81
atomic 6's Avatar
Originally Posted by dudeman
i agree. i think it is the sprag also. what kind of parts are needed to make a glide live?
Aftermarket gear set, for starters.
Did you know the second gear was gone before you made the run?
Old 12-11-2012, 02:59 PM
  #82
atomic 6's Avatar
Originally Posted by skinnies
5.5, yes someone beat it, but I don't care about that, making it live at the 1/8th mile is A LOT easier than making them live in the 1/4!
It is also much easier going for a record in a feather weight car, get some real tires on that LTD, and drop all those useless mufflers, to post up some good times with a car that will scale the same as the rest of us.
Old 12-11-2012, 03:16 PM
  #83
dudeman's Avatar
Originally Posted by valiant65
Congrats Dudeman!
Could you tell more about your valvetrain? Are you using any revkit? What valvesprings? Which lobes in the cam?
stock lifters, stock rockers, prc double valvesprings. i believe xer lobes but im not 100% on that.
Originally Posted by Blk4v00gt
May have already listed these details but what stall is your converter and what kind of boost controller are you using. Thanks
it was a 3800. i had my converter guy tighten it up some. he said it should be around 3500 now. i use the aem tru boost. its cheap and it works for what i have now.
i started pricing out part for the glide. looks like i will stick with a th400 for now.
i wasnt sure it was gone. after the 9.2 pass i checked linkage and it seemed fine. so i made another pass. ran the 8.81 and that was when i knew for sure i had no second. i didnt try to make any more runs after that.
Old 12-11-2012, 03:18 PM
  #84
atomic 6's Avatar
If you shift to 2nd and it does nothing(but maybe hit the rev limiter), then shifting to third gets third, it is the sprag.
Another thing you need to watch is the convertor charge pressure in a T400, too high and you will take out the thrust bearing in the engine.
This is what I am talking about, and the problem we saw when we put t400 behind the Turbo buick engines, and now the Turbo LS engines
Old 12-11-2012, 04:23 PM
  #85
rotary1307cc's Avatar
Same power and same weight stock 1.76 gearset has been running just spiffy for me
Old 12-11-2012, 04:25 PM
  #86
:rollseyes:
Old 12-11-2012, 04:30 PM
  #87
atomic 6's Avatar
If your not breaking the stock 1.76 gearset your not making enough power yet. turn it up.
Old 12-11-2012, 04:46 PM
  #88
TurboMonte100's Avatar
I'm not recommending that anyone do it, but I did unknowingly go pretty fast for quite a few passes with a stock 1.82 (6 cyl) gearset..
Old 12-11-2012, 04:53 PM
  #89
I agree that i dont see the point of going to a glide when a 400 is already in there and he has had it tame yet still mid 1.2s out of it with the 400
He wouldnt have a problem making the glide work though as far as power though that i know
Old 12-11-2012, 05:35 PM
  #90
Blackpanther99's Avatar
Amazing pass!!
Old 12-11-2012, 05:42 PM
  #91
71 chevy's Avatar
i agree with This. youve already run 1.25 with the th400, and it would cost $300 to fix, vs 2000+ for a well built glide..
Old 12-11-2012, 05:52 PM
  #92
01snake's Avatar
2,000? Where lol I've seen them 3-4gs
Old 12-11-2012, 06:00 PM
  #93
atomic 6's Avatar
The one in Mike's mustang was $4500, and another $1100 for the convertor, behind an $800 engine.
Old 12-11-2012, 06:09 PM
  #94
gobaltss's Avatar
wow, great pass, that things a monster
Old 12-16-2012, 09:58 PM
  #95
3pedals's Avatar
Awesome!
did you merge your 2.5" hot side pies together before the t-6 flange, or keep each bank feeding the divided turbo separately?
what fuel are you using?
Old 12-16-2012, 10:36 PM
  #96
Blk4v00gt's Avatar
What is your fuel system to support that kinda power on e85
Old 12-16-2012, 11:36 PM
  #97
dudeman's Avatar
thanks!
Originally Posted by 3pedals
Awesome!
i merged the 2.5" pipes to a 3" pipe that goes to the t6 flange. if the turbo had a divided exhaust housing i would have ran the two pipes to the flange instead.
it is on e85
i use FIC2000 injectors and a magnafuel 4303 fuel pump with magnafuel regulator. -10 to a Y block and -8s to each rail.
Old 12-17-2012, 10:18 AM
  #98
gnx7's Avatar
How loud is that Magnafuel 4303 pump? Is it as bad as an A1000 buzz bomb?
Old 12-17-2012, 10:51 AM
  #99
9sectruck's Avatar
If its any thing like my magnafuel 4703 its loud
Old 12-17-2012, 12:35 PM
  #100
dudeman's Avatar
its been a while since ive had an a1000, but im pretty sure its not as loud as the a1000.
Quick Reply: stock 6.0L 8.81@161
