what size turbo /injectors/tb/regulator
I have a have been. oing back and forth with trying to figure out this setup
People tell me you cant use a efi fuel regulator with the walbro pumps
And I hear go with a small turbo with a big motor then I see people with stock 6.0's with 70mm turbos . I have a
85 el comino
Stock L92 and heads
Gm single plane w/ elbow
Ls9 cam
Built th350 maybe a 2800 or 3000 stall
Grand national rear w/ 342 or 373s
Help
85 el comino
Stock L92 and heads
Ls9 cam
Help
stock truck intake, stock return rails, stock regulator built in, stock throttle, stock heads, gaskets, cam, etc etc will easily do 500+ with a gt45 turbo.
we did 500whp on a totally stock 4.8 and a gt45, valvesprings floating away!
i would recommend some cheap pac 1218 springs and hammer it with boost
<-I run one, rear mount, I need a bigger wastegate, and a stronger transmission. Stock 4L60e ain't cuttin it.
