Looking for wrapped truck manifold pics
I'm having a issue with burning up plug wires with my up and forward headers. With the dei wrap, can the plug wire sit on the wrap with out it burning the wire up?
I'm not wanting to relocate my coil packs, so hopefully just header wrap works.
digging this thread out of the deep dark depths of ls1tech.
For the stock ls1 manifolds should i use 1 inch or 2 inch wide wrap? i think the 1 inch would be easier to pass between the tubes but correct me if im wrong.
How much wrap will i need PER SIDE, 1"x50'? 2"x50'
Ill be wrapping my whole exhaust back to the rear mount turbo so give me an idea of how much ill need
do you guys like the spray or should i just leave them uncoated?
Thanks for the help
Thanks for the help
#33
Check this thread out.
https://ls1tech.com/forums/forced-in...fold-pics.html
#38
Got the humps all cut off and smoothed down with a grinder. I used dei titanium exhaust wrap. I bought two 50' rolls. I would say I've got about 20ft of each roll left over I can use on something else. Just wanted to make sure I wasn't going to come up short. It's possible to use the 25' rolls but I wanted to make sure I got everything covered. I used the 2" width rolls. You can see a hump on each manifold where I couldn't cut or grind down very much or else I would have holes in my manifolds.
![](http://i73.photobucket.com/albums/i218/Ryan0789M/Mobile%20Uploads/image_zps1f55eaaf.jpg)
![](http://i73.photobucket.com/albums/i218/Ryan0789M/Mobile%20Uploads/image_zps5d52ff2b.jpg)
![](http://i73.photobucket.com/albums/i218/Ryan0789M/Mobile%20Uploads/image_zps07590918.jpg)
![](http://i73.photobucket.com/albums/i218/Ryan0789M/Mobile%20Uploads/image_zps0699d8f6.jpg)
