Looking for wrapped truck manifold pics
Old Dec 22, 2012 | 10:28 AM
Taubr Unit's Avatar
Default Looking for wrapped truck manifold pics
Wrapping my complete hotside and wondering how to go about the manifolds. Thinking each pipe separately, 2 at a time, whole manifold all together...? Who wrapped theirs n have pics for ideas?
Old Dec 22, 2012 | 11:23 AM
9sectruck's Avatar
i wrapped mine.
i wrapped each cylinder individual, took forever going threw the holes with the hole 50ft roll, took about 40ft to do each one.
sorry never took one has it sit on the bench
Old Dec 22, 2012 | 11:48 AM
Grr's Avatar
Grr
Dont remember but I believe I started in teh back, its all one piece.
Old Dec 22, 2012 | 12:06 PM
9sectruck's Avatar
SAME HERE started on the last cylinder worked my way to the collector.
GRR about 40ft?
Old Dec 22, 2012 | 12:27 PM
Grr's Avatar
Grr
sounds about right, the majority of it is doubled up really holds the heat in well.
Old Dec 22, 2012 | 12:47 PM
MUSTANGBRKR02's Avatar
Damn Grr that looks good.
Old Dec 22, 2012 | 02:08 PM
Taubr Unit's Avatar
Those do look pretty sweet, not nearly as bad as I was thinking!! Thanks guys
Old Dec 22, 2012 | 02:16 PM
Grr's Avatar
Grr
BTW I cut off and smoothed the heat sheild bolt bosses on all the primaries, really made the wrap fit better and overall a better look. Just dont go too deep
Old Dec 22, 2012 | 02:40 PM
Taubr Unit's Avatar
Well my plan was to keep those and throw the heat shields on afterwards. Won't know till I actually get to that point and see how it all flows out when actually doing it.
Old Dec 22, 2012 | 03:34 PM
9sectruck's Avatar
I left my bosses for the same reason may end up putting the shields on if i dont like the heat around the line lock
Old Dec 22, 2012 | 03:44 PM
65panel5.3's Avatar
not sure if its a big no-no but when i wrapped mine i dunked the whole roll of heat wrap in warm water then wrapped them, first time the heat hits them they tighten up like piano wire and it really makes them look nice, also is nicer on the hands and arms because all those little fibers seem to come off in the water and not end up in your skin, just a thought.
Old Dec 22, 2012 | 03:57 PM
9sectruck's Avatar
lol yes i itched for two days after raping mine, the next time the rolls will be wet when they are applied
Old Dec 22, 2012 | 04:27 PM
L92 fox's Avatar
Did you guys notice a big change in under hood temps once you wrapped your hotside? I have coated up and forward headers and the under hood temps are unreal. I plan on wrapping mine very soon.
Old Dec 22, 2012 | 04:53 PM
Taubr Unit's Avatar
From what I hear, people can do a full out pass and right after in the pits they can touch them so I'd say it has to help a ton.
Old Dec 22, 2012 | 05:00 PM
FasTimeSS's Avatar
I plan on wrapping mine also, what brand of wrap are you guys using? I like how you cut off the taps for the heat shield bolts. I will most likely do this also what did you use to cut them off? Also what type of clamps are you using to hold them on? Thanks guys and sorry for all the questions.
Old Dec 23, 2012 | 08:20 AM
Grr's Avatar
Grr
Yes it makes a massive difference in engine bay heat. I had a coated tube header setup before that one. On a normal day i could drive the car, get out and scan the hood with me IR thermometer and get 240-270* temps on the hood surface.
Switched to the setup above and doing the same resulted in 190-210* temps. I could put my hand on these with the manifold glowing red for about 2 seconds, and the downpipe was nice to lean on even when hot
If you are going to wrap, the ONLY wrap to use is the DEI titanium, it holds up much better than the old style tan and grey wraps, and looks better.
To cut off the tabs, you can do it with a sawzall or just grind them down. The manifold is recessed inside under them so you cant cut them off flush, but even grinding them down so the hole is gone it just leaves a small bump that is easy to cover
Old Dec 23, 2012 | 10:03 AM
JAX04's Avatar
Yes What Grr said, The DEI Titanium wrap is perfect, and no itching afterwards for me. Not like the fiberglass stuff.
Old Dec 23, 2012 | 10:07 AM
Wicked69's Avatar
On the DEI titanium. After it dries does it feel hard like a cast? My wraps I dipped in water and wrapped and they were DEI but must have not been titanium. Mine never hardened up like a cast or got any tighter.
Old Dec 23, 2012 | 11:02 AM
Grr's Avatar
Grr
you dont need to water the titanium, it installs dry and remains soft and nice!
Old Dec 23, 2012 | 11:07 AM
pmgm's Avatar
Your turbo set looks good... Can you post some pics from the passenger side.. I would like to see your merge pipe..
Thanks
