What size Ebay intercooler and piping to get???
Old Dec 26, 2012 | 09:08 PM
mrstepheneades's Avatar
Boost drops the more bends you have?
Old Dec 26, 2012 | 09:15 PM
jridenour31's Avatar
Pretty much, restriction in the coldside causes pressure drop. It could be from the bends, piping diameter, intercooler...
Old Dec 26, 2012 | 09:17 PM
sweet99ss's Avatar
Originally Posted by mrstepheneades
Kit with piping? 3 in? Where?
http://www.ebay.com/itm/160387930769...84.m1423.l2649
Old Dec 27, 2012 | 08:03 AM
thanks for the link..... be easier to just buy the package deal like that....
Old Dec 27, 2012 | 10:50 AM
67Firebird455's Avatar
No kidding, that's not a bad deal at all with the T-Bolt clamps, good quality aluminum charge piping, and decent silicone couplers for our boost level!
Old Dec 27, 2012 | 12:22 PM
allout06's Avatar
look into a tread stone intercooler. I had a CX racing IC setup and im doing a TT build now, ive done decided to use a quality IC. I dont want any pressure drop. There have been issues with the IC cause a lot of pressure drop. but they work great for a budget build..
Old Dec 27, 2012 | 12:26 PM
You're going to have some pressure drop. It's not a bad thing, it just means the intercooler is doing it's job. Of course, you can have too much pressure drop if the core is too small/restrictive. I wouldn't say Treadstone is a quality intercooler and CX isn't. If anything, Treadstone has slightly better cores. Quality would be Garrett or Bell.
Old Dec 27, 2012 | 12:29 PM
Athlon2k2's Avatar
Do you guys just cut and weld the aluminum piping from this kit?
Old Dec 27, 2012 | 12:41 PM
You can weld it or use the couplers.
Old Dec 27, 2012 | 02:43 PM
coupler be more chance for boost leaks but way easier to take apart or put together in tight places.
Old Dec 27, 2012 | 02:53 PM
allout06's Avatar
if you cut it, make sure you bead roll the ends. a lot of guys will even spray the ends with aerosol hairspray and it act like a temporary glue. i blew off a coupler at 6psi on a non-bead rolled end. Ive decided im going to use mild steel this time around. itll weigh a little more, not much, but i can get a much tighter clamp force with it, unlike aluminum which starts to oval if you over tighten it. plus mild steel is easier to weld. just my .02. And i would say a treadstone IC is a little better quality..., im going with them because they have a twin 2.5" to single 3" out.
Old Dec 27, 2012 | 03:27 PM
  #32
Athlon2k2's Avatar
@allout06: so you used mild steel for your intake piping? I've been contemplating this because of my lack of a TIG welder and I hear using a MIG on aluminum is a pain. I could buy a TIG but that would cost most than my Turbo build.
Old Dec 27, 2012 | 04:54 PM
  #33
allout06's Avatar
I havent bought my IC piping yet but yes i plan on using mild steel. It might weigh an extra 10lbs but at least itll be easy to weld then i will have it powder coated. Ill b makin between 17-20psi so i really want a good clamping force on the couples and weld it where i can. Welding alumimum for a beigginer welder is very difficult from my understanding. I would do aluminum if i had a way to tack it all together and go have it TIGd, but i dont know how i would tac it
Old Dec 27, 2012 | 05:01 PM
  #34
LS1NOVA's Avatar
Ive used mild steel and its just fine.
If you want to use aluminum, make nice cuts, deburr it well, mark a line with a sharpie, tape it up, then take it to your welder.
Old Dec 27, 2012 | 05:03 PM
  #35
Welding aluminum isn't nearly as difficult as it's made out to be, but if you don't have the right welder it doesn't matter anyway. Fwiw, I've never had an issue clamping aluminum.
Old Dec 27, 2012 | 07:30 PM
  #36
allout06's Avatar
That was the only thing i could think of, but if the welder doesnt align the marks perfectly i would think youd have fitment issues...
i noticed i started smashing mine when i was tightening them, so i took easy, then ended up blowing a coupler off at 6 psi... so i cant imagine 3x more pressure. im sure if it was bead rolled it would of been ok though.
Old Dec 27, 2012 | 07:38 PM
  #37
Definitely, not only does bead rolling give the coupler something to grab, it also adds strength.
Old Dec 27, 2012 | 07:41 PM
  #38
The Sharpie and tape trick does work. As long as you mark it well, it will be close enough after it's welded that you can make up any differences with the couplers.
Old Dec 27, 2012 | 07:45 PM
  #39
Someone explain bead rolling to my ignorant mind? Maybe a picture would help...
Old Dec 27, 2012 | 08:05 PM
  #40
Athlon2k2's Avatar
It basically is a lip on the end of the pipe. Just like most the vacuum lines on our cars. You can buy the bead maker at harbor freight. Found this.
http://www.mittlerbros.com/index.php...eavy-duty.html
