Project s10
Old Mar 31, 2013 | 07:09 AM
  #81
TheRace1092's Avatar
so what specs did you go with on the turbo? and i take it you decided on front/rear mount?
Old Mar 31, 2013 | 06:07 PM
  #82
1fast bird's Avatar
The TC turbos have a .68mm turbine wheel. I went with a .96 exhaust housing.
Old Apr 17, 2013 | 10:00 PM
  #83
Tuckin15s's Avatar
Any progress?
Old Apr 18, 2013 | 06:31 AM
  #84
1fast bird's Avatar
I'm still collecting parts at the moment. Will update when I start to tear down the truck.
Old May 4, 2013 | 02:22 PM
  #85
1fast bird's Avatar
Got a question for anyone that knows..... Can I use a LS2 oil pan on a gen 3 block? Doesn't appear to have any place for a oil dipstick in the block, and no provisions on the pan Maybe I can't run the pan I got after all?
Edit: Gotta drill the block for it. The trailblazer 5.3's have the dipstick hole in the pan
Either way I have what I need to button up the motor now and the parts to install, so I will update soon
Old May 4, 2013 | 06:23 PM
  #86
Kory 88Iroc Lt1's Avatar
I have an ls2 vette pan on the 05 6 liter in my s10. the block has a dipstick on the pass side. I don't know if that helps you or not.
Good luck with your project.
Kory
Old Aug 26, 2013 | 06:26 PM
  #87
T76s10's Avatar
Whats up with the truck? I see its been a few months
Old Aug 26, 2013 | 06:59 PM
  #88
Blackpanther99's Avatar
Apparently he logged in today. Wonder if he forgot about the thread. Lol
Old Aug 26, 2013 | 08:25 PM
  #89
ZQ8LS1's Avatar
Subscribed !
Wanna do a front mount & looking for ideas.
Old Aug 26, 2013 | 08:40 PM
  #90
Jamescassy's Avatar
Originally Posted by ZQ8LS1
Subscribed !
In an s10 ? I am doing mine 95 Sonoma and 5.3 jamescassy on you tube Sonoma ls1 swap videos will post new ones ! Pm me for any questions am willing to try to help !
Old Aug 26, 2013 | 08:46 PM
  #91
ZQ8LS1's Avatar
Yep...I already have the 5.3 installed & looking to go turbo. Make take a while
Its a daily driver & I wanna keep it that way...ac & all.
Old Aug 26, 2013 | 08:52 PM
  #92
Jamescassy's Avatar
Mine is different Sunday driver . But I found Sanderson shorties work well for me for front mount . But I have ac delete and am using two driver side headers the driver side in regular position clears steering shaft and brake booster . Then another driver header on passenger side upside down and backward lol front mount for me but with ac and all I haven't seen any front mount in s10 how are you going to do it ?
Old Aug 26, 2013 | 08:58 PM
  #93
ZQ8LS1's Avatar
Right now just looking for ideas....
  #94
dschmittie1's Avatar
I don't think he forgot about it. We have talked about it but I think he has been lacking some of the motivation to work on it. Next week he is going with me to LS Fest so he should have some renewed interest after that
Old Aug 26, 2013 | 09:25 PM
  #95
T76s10's Avatar
haha thats the exact phase i went through. went to one car show and all of a sudden started building my truck again. its funny how that works
Old Aug 27, 2013 | 08:27 PM
  #96
1fast bird's Avatar
I got as far as collecting parts in my Summit cart and tearing the front end of the truck down. The 4.3 is ready to come out, but my motivation has been less than great. Don't worry, I will update when I finally get tired of being a slacker!
Old Oct 24, 2013 | 05:27 PM
  #97
1fast bird's Avatar
Well I finally started on this project have made a little progress in a few hours of work. Got the 4.3 and trans pulled. Notched the cross member to fit the Ls2 pan and dropped the 5.3 in. For now I have the stock rubber mounts but will be replacing them with poly mounts soon. It looks like I will have to fab up a new trans mount and delete the stock crossmember since it appears to be 3" front too far.
Anyway, I've started and have some motivation to work on it....
on a side note I may be selling the 8.5" rear out of it in favor of a 9". Can't make up my mind on this but it's been a thought.
Some pics of progress.
Freed up a ton of room with the ac delete heater box....
Old Oct 24, 2013 | 05:38 PM
  #98
2ktransam's Avatar
about damn time. LOL That ac delete box does make a huge difference. You might actually be able to fit a log setup in there.
Old Oct 24, 2013 | 06:08 PM
  #99
1fast bird's Avatar
I think a log manifold will work, but not how I planned it to. So far I had a 3.5" pipe in where I think the downpipe will be and it appears that feeding the back of that mani won't happen. It will need a merge somewhere else. I have my work cut out for me for sure.
Kris, is your trans crossmember stock or modified for the 4l60?
Old Oct 24, 2013 | 06:30 PM
  #100
2ktransam's Avatar
Originally Posted by 1fast bird
I think a log manifold will work, but not how I planned it too. So far I had a 3.5" pipe in where I think the downpipe will be and it appears that feeding the back of that mani won't happen. It will need a merge somewhere else. I have my work cut out for me for sure.
I think mine is the stock crossmember. It looks like they just moved it back and drilled new holes in the frame to bolt it up. Let me know if you figure out how to fab up a driveshaft loop.
