Project s10
Old Jan 18, 2013 | 07:08 PM
  #41
JAX04's Avatar
I happen to love it!
Old Jan 18, 2013 | 07:44 PM
  #42
1fast bird's Avatar
I'm pretty happy with it now that I don't have to cringe everytime the front scrubbed the inner fenders.....It was actually scarey on the highway since it would pull to the side when one tire would touch. I'll love it even more with a nice little 5.3 and a bit of boost....If I can ever find a decent motor that is.
Old Jan 18, 2013 | 09:11 PM
  #43
2ktransam's Avatar
Looks good. I hope these springs don't settle a ton. I'm going to put the spacers in the front of mine to raise it a little more. I need all the room I can get under the truck for the intercooler pipe.
Old Jan 21, 2013 | 02:36 PM
  #44
TheRace1092's Avatar
i think the heigth looks good. but how u plannin on runnin your cold pipe to the engine without draggin or are you doing a engine compartment turbo? also what happened to the window tint? did you remove it?
Old Jan 21, 2013 | 04:06 PM
  #45
1fast bird's Avatar
The turbo will be a front mount. Had to take the 5% tint off the sides cause it was a tad too dark for my taste. Not to mention a cop magnet around here. I plan to get 20-35% put back on at some point
Old Jan 23, 2013 | 05:25 PM
  #46
im with ya. yea imho anything darker than 20 is just so you can say hey look what i got!.understand about the cop thing as well. so with a front mount your no doubt gonna have alot more underhood heat. what are you going to do for cooling? fans/radiator?
Old Jan 23, 2013 | 06:59 PM
  #47
1fast bird's Avatar
Just going to use the 4.3 radiator and some fans from a Intrepid. Also everything will be wrapped and the turbo will have a blanket...... Try to keep the heat where it's supposed to be
Old Jan 24, 2013 | 10:08 PM
  #48
ive heard of using intreped fans. what makes them better than say ls1 fans from an fbody?
Old Jan 25, 2013 | 04:23 AM
  #49
southernendperforman's Avatar
I've seen that truck before, guy I work with had it a couple months ago. Ever seen my s10 around in lancaster area?
Old Jan 25, 2013 | 01:03 PM
  #50
1fast bird's Avatar
Do you work at Herr's? He works there in Nottingham, his name is Leroy. Never seen your truck, but it looks awesome! How's that thing run?
Old Jan 25, 2013 | 01:05 PM
  #51
1fast bird's Avatar
I'm guessing the intrepid fans are lower profile and easy to make fit. Plus they are cheaper than f body fans
Old Jan 25, 2013 | 04:52 PM
  #52
Yea that's where I work and yea that's whose truck I thought it was. Truck goes 10's but can't get it to hook. You'll love puttin a v8 in yours, good luck.
Old Jan 25, 2013 | 06:46 PM
  #53
1fast bird's Avatar
Maybe I'll see you around sometime.....then we can line them up
Old Feb 1, 2013 | 08:21 AM
  #54
1fast bird's Avatar
Decided to see if my Street Lites that I had on my T/A would fit the s10. To my suprise the rears fit! These are a 10x15 wheel with 4.5" backspace. Couldn't run it like this unless I cut the fender lip off, but it looks so damn cool!!! What do you guys think?
Old Feb 1, 2013 | 08:27 AM
  #55
Blackpanther99's Avatar
Looks badass! They really make the truck stand out.
Old Feb 1, 2013 | 08:30 AM
  #56
s-10ls1's Avatar
Looks really good!
  #57
1fast bird's Avatar
Thanks. Gotta order some 15x10 with 5.5" backspace or 15x8 with 4.5" backspace. I'm shocked the 325's fit!
Old Feb 1, 2013 | 08:54 AM
  #58
BudRacing's Avatar
Looks great! Roll those fenders.
If you want to raise the front up some more AND gain some improved handling characteristics Howe makes some tall lower ball joints. It will increase the ride height by about 1/2" in the front and reduce understeer and decrease tire wear when cornering hard. It's basically improving the camber curve.
Old Feb 1, 2013 | 08:59 AM
  #59
TURBO10's Avatar
Stay with the 4.5 BS. The leaf spring is the issue there.. If they make a 15x9 w/4.5 BS that would be the shiznit..... Im building on to and have built several SBC S10's/Blazer's
Old Feb 1, 2013 | 09:49 AM
  #60
1fast bird's Avatar
I want the tire to tuck a little more than that....plus I offered the wheels to the guy buying my T/A rear.
Thanks for the info on the ball joints...I'll look into that
I had over an inch of clearance on the inside with 325/50/15's. A 10 inch wheel with 5.5" backspace should clear with a 275 tire without issue. But I am leaning towards an 8" wheel so there won't be any question that it would fit.
