magnum xt80 or s475/83 both in T4... which will flow more?
#42
First of all:
BW S475/83: 83mm inducer/75mm exducer
Magnum: 88.9mm inducer/77.4mm exducer
Second of all CX racing makes the exact same turbo for half the price. Plus, at CX racing you have the option to get that turbo with a 76mm compressor! I just bought one lol! I'm not shittin you, it looks like they took magnums turbo and ground all the part numbers and logos off of it lol.
http://www.cxracing.com/mm5/merchant...ry_Code=TRBT35
Here's mine next to a TC 76/68 (notice the spots on the housings where they ground something off)
That is actually the one i ordered and still waiting for it. I knew it was the same thing so i figured why confuse everyone with a turbo they know nothing about. I could still cancel the order and run my BWs475 but i think Im just gonna run it
#44
#47
welp plans changed like always! sold the 475 for a pretty good price.
cxracing still hasnt shipped the turbo so i still have some time to weight out my options and now im looking at the Turbonetics 7875 .96 or 1.15 AR....
what do you guys think about the turbonetics 78/75 over the magnum 80mm?
#50
#51
#52
Just saw Ren's post. We just swapped my old on3 out for this cxracing 80 and it is a beast. Like he said, it comes to life real quick with my TU1 5.3. With the old turbo my IDC was at 57% at 14.3psi, with the new turbo my IDC is a 67-68% at 12 psi lol. So it is moving some air! The downpipe flange is a regular 4" v-band and the compressor outlet is 3.5" v-band. I also knife edged the divider on the turbine housing.
#53
No oil restrictor, just straight -3an feed and -10 return. Ive only turned it up to 14psi and I have no doubt it's making 650 rwhp through a th400. I cant wait to upgrade to a 3 bar setup and see what it does past 15psi, just need to find the time
#55
Any updates, anyone, on the Magnum XT80 or the CX 80? I'm considering one of these for my 4.8 1972 Camaro in lieu of twins...
Anyone care to share some results?
#60
I just picked up a Meth kit with Dual Nozzles for that reason.....should be an interesting formula for my 2900 lbs 240sx chassis if it can move your truck like that. OP thanks for this post def added a different variable into my build.
