I finally got anti lag to work!
Pulled down to -10 degrees at 2800, 2 step at 2950. Yes, -10 degrees of timing when it is activated.
Mike
http://www.youtube.com/watch?v=2SIHY...ature=youtu.be
You need to have at least 24-28 degrees in it when you're building your initial 7-9psi of boost if not 28-36*. Think N/A tune-up until you're solidly into boost.
I went outside last night and messed around with it with more timing, moved the 2 step up, moved the retard up, but I am still having issues. I am going to move everything down next, the 2 step and where it dumps timing. I don't understand why I am struggling to build 10 psi, but Matt was able to just drop the hammer and build 14 quickly. It seems like I am not making it to ignition cut, but he did quite easily.
This is the timing table:
Mike
Then have your launch control triggered by a switch to cut timing once some boost is built.
Is that correct?
Mike
Is that correct?
Mike
What I would do is where you're currently at 22, 24 and 26 degrees of timing in the 2800rpm cell from 80-125KPA change it to read 32 degrees at 80KPA, 28 degrees at 100KPA, 26 degrees at 125 and then 22 degrees at 150kpa and then at 220 have it back to 15 degrees. Then from 2800rpm and lower rpm in the corresponding 80-150KPA cells copy and paste the changes you just made.
Also where you have it at 34 degrees at 50kpa right now in the 2800rpm cells I would leave it at 34 degrees all the way to 60kpa and then at 80kpa have it at 32 degrees like I suggested in my above paragraph. Then copy and paste the 34 degree cells from 50kpa to 60 kpa in the corresponding 2200rpm and 1800rpm cells.
Do you still have TR6 plugs in that thing?
Also, how much timing do I dump? As you see, it dumps not a specific amount of timing, but TO a specific amount of timing. So, if I am dumping timing at 2700 RPM, I need to know what to command the timing to be, or how much to pull and I can figure out the number.
Mike
Mike
I always pulled between 8-12* and it worked very well for me, BUT I had to have at least 7-8psi built before I could dump the timing or it would never spool.
Mike
Use the retard, but it'll be trial and error to find what works best. Keep an eye on EGT's when testing though, as they can get very high very quickly using this method.
I'd have thought that 10 deg ATDC would have been enough to really have it spool up though. But you're basically firing the spark with the exhaust valve open so it drives the turbo instantly.
Mike
Mike
If you try to retard the timing you end up taking forever to build boost which puts too much heat in the trans and on the exhaust valve.
Try what I suggested with the timing table and see what it does. I think you will find that you're able to build boost much faster with advanced timing than with retarded timing.
Here is the table now, please let me know if this is what you had in mind. I also have the anti-lag set to pull the timing down to 10 degrees total, which I will push once I have built some boost.
Mike
Mike
That looks like a good start. Just think about it this way, we run N/A engines at 93-98kpa at 28-30* timing. Why not run a boosted engine at 22-28 from 1-5psi? If you think about it that way it's not so bad. I've run my personal cars this way and plenty of other customer cars, actually more timing than what you currently have in that table.
I think another reason Matt hurt the rings is from too hot of a plug which is why I asked you if you still had the TR6's in there. I'd run a -8 heat range projected tip if I were you.
Mike
