High compression with turbo questions
thats what im going to run.. 76mm turbo on a 347 ls6 engine.
Hell I ran my 9.5:1 motor to 15# on pump gas with no intercooler
A cam with the proper valve events will bring the dynamic down a touch and widen your tuning window when it comes to timing.
If you dont change it. Ill be surprised if you get 14 degrees in it.
The reality of it is..we put the static in it so we can run the big cams to get the cylinder filled as much as possible and still create a ton of cylinder pressure.
High compression with a small cam that has no overlap is gonna make for a overly sensitive motor on the tuneup.
