High compression with turbo questions
Old Jan 14, 2013 | 01:14 PM
370cidZ06's Avatar
Originally Posted by LilJohn
Id pick a different cam to run. The LS9 cam is gonna create a **** ton of dynamic and the thing has negative 22.5 degrees of overlap at .050.
A cam with the proper valve events will bring the dynamic down a touch and widen your tuning window when it comes to timing.
If you dont change it. Ill be surprised if you get 14 degrees in it.
The reality of it is..we put the static in it so we can run the big cams to get the cylinder filled as much as possible and still create a ton of cylinder pressure.
High compression with a small cam that has no overlap is gonna make for a overly sensitive motor on the tuneup.
Any cam suggestions that don't cost the usual 400 my buddy has a ms3 for cheap and stock ls1 and a stock ls6 cam?
Old Jan 14, 2013 | 01:19 PM
LS1 240sx's Avatar
I would run something bigger then 100lb injectors. I was on E85 on my 5.3l (317 heads), aeromotive 340lph stealth (badass and quiet) and 18 psi at 19 degrees of timing and with 120lb lucas injectors I was already at 78% duty cycle@ 58psi fuel pressure.
However I NEVER saw knock. I took timing to 21 degrees and leaned it out to 12.5:1 AFR and no knock and one point it went to 13.2:1 AFR and still logs showed no knock. Car pulled sooo hard I felt like my ***** went back in my gut.
Now im on pump gas with 14psi @ 21 degrees of timing at 11.2:1 AFR and no signs of knock. However I have other kinks to finish.
I think with E85 at 12psi from a 76mm you will net 600whp easy, I dont know that much about valve events but I know Liljohn knows what he's talking about. Is this 370ci block?
Old Jan 14, 2013 | 01:23 PM
Grr's Avatar
Grr
John makes a good point I overlooked the LS9 cam, I hate that cam
Im not that concerned with the dynamic, but get some cam in it! BTW a 70mm on your setup would likely not even make 16#, you shold be well over 600whp at 10# or less.
Old Jan 14, 2013 | 01:41 PM
370cidZ06's Avatar
Well I am not trying to spend a **** ton of money on this setup since it wont probably last too long , so if I spend 400 on a cam ill just buy my nitrous cam and spray it with the 200
Old Jan 14, 2013 | 02:11 PM
LilJohn's Avatar
PM Automagic LS1...
He just pulled an older MTI R1 out of his motor thats 232/236 114+4 iirc.
Itd be a good one to use since youre building this as a throw away type motor.
Prolly get it for half the price of new.
What turbo are you looking to run?
Old Jan 14, 2013 | 02:28 PM
370cidZ06's Avatar
Idk I have a mpt70 laying around was thinking about that since its here but right now I'm having issues with hot side routing
Old Jan 14, 2013 | 02:34 PM
87silverbullet's Avatar
BAKED on here is one of the nitrous turned FI guys on here. He has a 11.5:1 346 that he was hitting with a decent shot and just put a turbo setup on it and runs E85. Its making stupid power on minimal boost too.
Old Jan 14, 2013 | 02:41 PM
LilJohn's Avatar
A single mpt70 isnt gonna cut it. Turbine is too small.
Now a pair of them......
Old Jan 14, 2013 | 02:52 PM
370cidZ06's Avatar
True but I need to figure this hot side first
Old Jan 14, 2013 | 04:46 PM
LilJohn's Avatar
I wouldnt call 25 psi "minimal boost".
Old Jan 14, 2013 | 05:39 PM
LS1 240sx's Avatar
HAH
Old Jan 14, 2013 | 07:33 PM
  #32
370cidZ06's Avatar
Well I can't find anyone who has or makes a hot side for under 2300
So if that is the only thing I can find no turbo for me. my original plan on making hits use won't work. G#d d@mn it
  #33
370cidZ06's Avatar
Old Jan 14, 2013 | 07:47 PM
  #34
Burken01's Avatar
Why don't you procharger your car?
Old Jan 14, 2013 | 08:06 PM
  #35
370cidZ06's Avatar
Everybody and their mother out by me has a procharger I would much rather slit my wrist vertically than do that
Old Jan 14, 2013 | 10:44 PM
  #36
HRHohio's Avatar
Just puttin this out there... On3 has come onto the scene...
https://ls1tech.com/forums/forced-in...ls-photos.html
First post says, "under $1999"
Good Luck.
Old Jan 15, 2013 | 08:45 AM
  #37
Considering guys run stock 5.3's and 6.0's on 20 psi I would consider 25 minimal in my book.
I have an OFI hotside I can sell you for 2300. Its all stainless for a T6 and has never been used. Downpipe can be used with a stock k-member from what I'm told. I can get pics if you are interested.
Old Jan 15, 2013 | 04:18 PM
  #38
gnfast87's Avatar
two words
Methanol Injection
I bought mine from alky control. Great kit
