On3 turbo woe's
Pull it apart and see what happened, then and only then will we know where the blame lies.
Keep in mind, a number of the users in this forum are squeezing more than double the factory output out of engines designed to go in "mom's" tahoe or "dad's" work truck. Things are going to break, parts are going to fail, it is a fact of life, all you can do is figure out what caused the failure then develop a solution to ensure it won't happen again.
i talking about the top of the line profession turbos.
heres one just for an example right off ebay that comparable size to an On3 T76 that he would get if he wanted a top dollar turbo
http://www.ebay.com/itm/Precision-76...d59bbb&vxp=mtr
No comparison. You are comparing a Billet Ball Bearing turbo with a warranty that has a 75mm turbine wheel to a Cast, Journal Bearing turbo with a 65mm turbine wheel
1500 is the middle turbos. he seems to have rediculous high standards like my father in law so im just putting the big new shiny turbo out there. he bought a cheap turbo and was disappointed, so heres a nice big expensive well known name branded precision turbo that everyone know about and has used. You want big company customer service, you pay big company turbo prices.
heres another for a turbonetics thats around the 1500 price range thats again in the 76mm range
http://www.ebay.com/itm/Turbonetics-...fe6f30&vxp=mtr
Again, a Billet Ball Bearing turbo with a 75mm turbine wheel to a cast, journal bearing turbo with a 65mm turbine
Hell, the new Compturbo turbos are in the $2500-3000 range for their oiless turbos, if that aint a tough pill to swallow.
We are direct with them, they certainly are not that pricey
then it goes down hill from there. heres some helpful suggestions since he dosent want to go cheap on his next turbos, if he finds them used then obviously he can get it cheaper. hes made up his mind so no need to keep pressing him to keep buying ON3. he isnt going to and that his business.
Actually it goes uphill from there, as a better comparison of turbo's would be a direct replacement Turbonetics TC76, which has a cast compressor wheel, journal bearing center, however it does use a higher flowing 68mm turbine wheel. These come with a 1-year hassle-free warranty backed by terrific customer service at $723
id suggest that he investigate the current problem so that everything is kosher in his current build so that he doesnt have any issues with his next turbo if there happen to be an unforseen obstrutions to the turbo from somewhere other then the turbo. Dont want the same thing happening to a 3x expensive turbo. Make sure its just the turbo that causing the problem and not not a piece of welding slag that got sucked up into the turbo and is bedded into the housing but is causing enough obstruction to catch the wheel or somthing like that. you have to fully diagnosis the problem.
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
You cannot compare the old copied technology of the T76/65mm exhuast to a 7675 or BB 7675. Of course they are more expensive, but they are not in the same class. Plus good used turbos can be had at a good price as well.
If/when I buy a china turbo(a properly sized one), and it does go out on me(hope not), I wont be suprised, like it should have lasted a super long time. it is what it is. you can buy 2 china's for the price of one good one, waht do you expect? the same performance/technology/longivity?
BTW if On3 wont do anything pull that turbo apart and see what happened? maybe it wasnt quite balanced correctly?
next will probably be a couple borg warners, or maybe a big single.
As for the balancing and just pulling it apart to look, there is nothing you can visually do to just look at balancing. There are tools associated with checking a shaft to make sure its balanced
Who do you think you are, not sending customers parts they paid for because of your vague recollection of the fact that they may(or may not) have disrespected you??? GTFO with that
Another quality sponsor
To the original poster, hopefully you can get things squared away with ON3. To ON3, I'd be pissed to if I ordered something and never got it. But that seems to be the case with turbo companies.
of course before the revelation im being screamed at and threaten then comes to find out he's the idiot. Im a firm believer in treat others politly and fair and that the customer isnt ALWAYS right. There has been a few times that ive refused service to customers because they have become touble some and a negitive atmosphere in the shop. NOw i dont know the history between ya'll and dont care to know, none my buisness, i dont know the circumstances of this buisness transation but if ON3 is willing to fix the problem id let them. and little humitity goes a long way.
