How to Microsquirt fuel and spark your LSX swap (sloppy mechanics how to!) 8-10-13
Old 08-16-2014, 10:31 PM
  #181
yenkomike's Avatar
I built my harness and it does not get hot I drove it in traffic on woodward for 3 hours today . id say you have a bad box or your harness has a short or is wired wrong. so far I love mine.
Old 08-17-2014, 08:23 AM
  #182
aknovaman's Avatar
Laundry, if you mail me your micro I can set it up for a Lsx and test it for you. Pm me if interested.
Old 08-17-2014, 02:44 PM
  #183
lxwithlaundry's Avatar
When my tunerstudio shows the ecu is live my dashboard gauges work and everything seems fine.. harness doesn't get hot just the ecu.. and it has good grounds and high 12 volts every time.. think I'll take you up on your offer aknovaman.. need to figure it out asap..
Old 08-17-2014, 03:04 PM
  #184
Moderator
denmah's Avatar
most of peoples connectivity issues are because of a USB to com port adapter that is flaky.
Old 08-17-2014, 04:10 PM
  #185
I'm using the 9 pin com port cord supplied and tried another that I got with a innovate LC1.. my laptop might not be up too par tho but seems fine..
Old 10-06-2014, 03:04 PM
  #186
Taco33150's Avatar
Do you still need to modify the Ecu to run microsquirt on the 8 coils..you had a picture with jumper wires..
Old 10-06-2014, 03:44 PM
  #187
yenkomike's Avatar
you can buy it done from efisource or look at the how to micro article under denmah's name in all of his posts. it has a pic.
Old 10-18-2014, 03:09 PM
  #188
Taco33150's Avatar
The microsquirt will run all the sensors?? I don't need the gm harness??
Old 11-16-2014, 05:27 PM
  #189
b00sted's Avatar
I'm interested in buying the EFI Source modified Micro to run spark-only on a carbureted LS1. Does anyone know if this will work alright? I'll only be using the factory crank and cam sensors, as well as a basic MAP sensor... Factory-style LS coils. No TPS, IAT, injectors, etc.
We were running the MSD 6010 box with factory coils, but it's a piece of ****. It can't seem to keep up with the power this engine makes on nitrous.
Old 11-16-2014, 05:28 PM
  #190
xx_ED_xx's Avatar
I think you will need tps and iat at least
Old 11-16-2014, 05:39 PM
  #191
b00sted's Avatar
That would kind of suck. I actually think there's kits out there to set up TPS on a carburetor, so who knows.
I don't need anything advanced. Just a basic timing curve based off of RPM, nitrous retard, and a 2-step...Both of which I'd like to activate via WOT/push-button switches.
Old 11-16-2014, 05:41 PM
  #192
xx_ED_xx's Avatar
unfortunately the squirt needs a reference signal to go by and ect.
Old 11-16-2014, 05:55 PM
  #193
b00sted's Avatar
I guess it isn't the end of the world. Holley offers a bolt-on TPS kit for $115...I could use that to activate the nitrous as well and ditch the WOT switch.
Old 11-17-2014, 12:15 AM
  #194
atomic 6's Avatar
I.E. it doesn't let you control dwell....LOL
Been there...
You don't need the tps, or the iat, hooked up for the Microsquirt to control timing, they are used mainly in the fueling calculations, the iat can be used in some of the timing calcs, but you could zero those out in the tables easily.
BUT...
An IAT is pretty easy to hook up, so you may want to use it. And even if you only use the IAT sensor to measure the ambient air temps,changes in timing could help with some extreme hot/cold starting conditions.(street car only problem)
If you go to the extra work to hook up the tps, even just to report WOT(tps hooked to a WOT switch, like some BMWs are from the factory), you could use the squirt to control some of the nitrous stuff.
But for just timing control,and none of the "extras" you don't need tps or iat hooked up.
And just a note, you don't need the cam sensor hooked up either, not with a Microsquirt setup.
Old 11-19-2014, 08:09 PM
  #195
Moderator
denmah's Avatar
you could also use the FIDLE output wire to trigger the nitrous system for you under certain conditions.
i would just inject it at that point then also haha
Old 01-30-2015, 12:12 PM
  #196
stacy moore's Avatar
Boost Solenoid w/ Micro has anybody done it - if so how????
I was looking at this one from DYI and was hoping it only needs a output from the microsquirt.
EBC Electronic Boost Control Solenoid Kit
http://www.diyautotune.com/catalog/e...kit-p-285.html
Old 01-31-2015, 01:41 PM
  #197
redss82's Avatar
you can run it off fidle not sure if you still need to wire it this way http://www.msextra.com/doc/ms2extra/...ware.htm#boost or if its different with the 3.5.7 micro
Old 01-31-2015, 03:33 PM
  #198
Moderator
denmah's Avatar
you would have to call EFI source, i think it needs the pwm break out board,
the ms3 can directly drive the solenoid
Old 02-04-2015, 08:05 PM
  #199
I called EFI Source and Mike said the Microsquirt V3 that's modified for a LSX motor car run the boost controller off fidle. fidle on one side and 12v on the other.
Old 02-04-2015, 10:03 PM
  #200
Moderator
denmah's Avatar
sweet, i wasnt sure if it could directly drive PWM
Quick Reply: How to Microsquirt fuel and spark your LSX swap (sloppy mechanics how to!) 8-10-13
