How to Microsquirt fuel and spark your LSX swap (sloppy mechanics how to!) 8-10-13
#342
I was running staged injection last year, and made the switch to ethanol and full sequential by tieing the injectors together. I'm running FIC1000's at 50psi base pressure and FIC540's at 55psi base pressure. Together it's right at about 1690cc's of fuel
The deadtime table is running the 540usec percentages
I'm getting another set of 1000's soon and can run the batch fire test again
#343
http://www.ebay.com/itm/4x-New-1700c...JYJBjl&vxp=mtr
#344
I saw this and remembered seeing something along those parameters on ebay. Here is the link to what I found today. 1700cc Hi-Z...Has anyone tried these out?
#346
Hard to tell if the pintle is plastic, looks like it might be stainless from the pictures...
So, are they a good investment as a step up from the 80's if you need more injector?
#349
You don't run 70psi of base fuel pressure with a rising rate regulator though. Justin (Skinnies) rx7 made 855whp on a mustang dyno. Some of the F bodies they tuned are in the mid to high 700 range with factory fuel lines. Not saying the dyno's couldn't be off a little, but the rx7 trapped 168....factory returnless style fuel rail w -6 to the rail. 3 255 hp intank pumps.
Saw the RX7 in person when it ran those numbers at our local track. Sure looked like 80's anyway and that's what he is claiming. I've never run them myself. Just installed a set on the twin 72mm junker mustang I'm putting together. Hope to see what I can squeak out of them.
![Name: halloween001.jpg
Size: 123.3 KB](https://ls1tech.com/forums/attachments/forced-induction/592688d1501249990-how-microsquirt-fuel-spark-your-lsx-swap-sloppy-mechanics-how-8-10-13-halloween001.jpg)
#350
Is this the tune that comes with the LS1 24x midified Microsquirt V3 from EFI Source?
Fairmont gasoline micro2 tune - http://sloppymechanics.com/tunes/Fai...2_gasoline.zip
5.3/80lb siemens deka injectors, 50psi, 80mm turbo, ls9 cam, ls1 intake, stock throttle, mix matched heads, 650rwhp on 24psi
