How to Microsquirt fuel and spark your LSX swap (sloppy mechanics how to!) 8-10-13
Old 03-15-2014, 04:49 PM
  #161
xx_ED_xx's Avatar
make sure it is bottomed out to the TB so it doesnt idle fast
Old 03-16-2014, 07:58 AM
  #162
aknovaman's Avatar
Unplug it and block the inlet passage in the throttle body. Then use the idle speed screw to adjust for idle. Be sure to calibrate the gps when done so micro knows where zero percent is.
Old 03-16-2014, 10:20 AM
  #163
yenkomike's Avatar
I built a manual iac and it is working good but next im going to run a vac hose in the car to a small ball valve and mount it so I can open it for fast idle and once it warms up I can close it for my hot idle speed . i'll post how it works.
Old 04-09-2014, 03:07 PM
  #164
Moderator
denmah's Avatar
updated for wiring fixes and changing out the spark resistors
Old 04-09-2014, 03:32 PM
  #165
tonypaul's Avatar
so even though my microsquirt has been working great since the install should I go ahead and wire the browns to the heads?
Old 04-09-2014, 04:30 PM
  #166
Moderator
denmah's Avatar
up to you, some people notice spark and input problems
Old 04-26-2014, 07:36 PM
  #167
jprince's Avatar
assuming to check for the resistors I need to open up the micro... and the brown wire on each coil should we simply cut it coming off of the coil, put a eyelet terminal on each one, and then ground each coil to the head?
Old 04-26-2014, 08:08 PM
  #168
tonypaul's Avatar
Just run all the browns in a series all going to one wire and ground that one wire to the head..
Old 04-26-2014, 08:12 PM
  #169
jprince's Avatar
10-4 ill give it a go ty
Old 04-26-2014, 08:48 PM
  #170
Tanus's Avatar
has anybody else wired in shift control to their microsquirt?
http://www.theturboforums.com/thread...nyone-tried-it
Old 04-28-2014, 07:41 PM
  #171
jprince's Avatar
Wired the browns to the head... in my case huge imorovment in the smoothness of the engine
Old 04-30-2014, 07:29 AM
  #172
Moderator
denmah's Avatar
awesome this is what we are seeing
also the 3.24k ohm resistors on the coils work with all coils we have tested so far, the 4.7s were causing problems with some coils.
Old 04-30-2014, 07:30 AM
  #173
Moderator
denmah's Avatar
Old 04-30-2014, 08:38 AM
  #174
quickkris2006's Avatar
Does this have a launch controller/ 2 step built in or is that something you have to buy separate like the the msd 8733 and wire it in?
Old 05-07-2014, 07:59 AM
  #175
rt338b's Avatar
What if you have the coils relocated off of the heads and are using a torque limiter that would probably cause a ground because it is going from engine to chassis?
Old 07-20-2014, 11:02 PM
  #176
99 Blue Bird's Avatar
Hate to bring up an "older" thread. But. How are the fuse panels being tied into the harness, and what are the fuses for. And why are the. Microsquirt boxes wired differently from Efi source than how denmah reccomends wiring the box. I just noticed how much different the complete LS efisource harness looks compared to the ones I have seen on here. Please guys help this microsquirt newb out since I am wanting to pick one up.
Old 07-21-2014, 07:47 AM
  #177
aknovaman's Avatar
Just wire your fuses as in this diagram and you will be fine as it protects all the necessary current drawing parts.
http://www.useasydocs.com/details/ew3_hires.gif
Old 07-21-2014, 01:11 PM
  #178
Moderator
denmah's Avatar
it has a launch limiter, and ANTI LAG so you can build boost
not just a stutter box
unsure what you are asking but it should work fine, may need grounds tied to where your coils are also, i know the Mockstang boys have off head coils on their 8.70 car running micro
well, they wire it so everything is fused separately for ease of use and probably because that is the correct way
i just combine alot of it to make it easy as i think that many fuses and relays is too many...
i use a 5amp, and tie that to the crank signal power and micro ecu main power i actually clip it like 5 inches off the main and tie them together there actually
i do it slightly different now and maybe i should update and show a video
i use the fuel pump relay now to kick the fuel injector and spark power feed.
the rest i throw a 20-30amp on, and combine it for all injector and coil power
in my experience it sucks when the coil or injector fuse blows and you still see one or the other, i would rather have it not inject or spark at all if there is a issue.
other people like to be able to pull fuses for checking problems and want to see just spark or just fuel, etc
depends on what you are doing but i just use that 2 fuse setup
same thing for STOCK pcm rewires
Old 08-16-2014, 09:10 PM
  #179
lxwithlaundry's Avatar
I've pretty much followed this tread to the t and I'm running into issues. first when I tried loading firmware it wouldn't wake up the prosessor.. once after many trys I was able to get that it stopped half way through loading firmware.. finally after many other trys it loaded.. and I could pull up tunerstudio and try the bench tune.. seemed to load it fine.. and went live.. tps worked and then goes offline out the blue.. I switch it off and start it back it goes live and then offline.. so seems I'm stuck..
Ohh and my micro box gets hot around the area where the t in microsquirt is.. seems as if the hotter it gets the faster it goes offline on restart.
Old 08-16-2014, 09:12 PM
  #180
xx_ED_xx's Avatar
Welcome to the world of squirting...
Quick Reply: How to Microsquirt fuel and spark your LSX swap (sloppy mechanics how to!) 8-10-13
