Need recipe for a responsive street 4.8/5.3
Going to do a turbo 96 'stang with either a 4.8/5.3, PG or TH400, and a GT rear with low 3.xx gears. I'd like to use either truck or F body exh manifolds, completely stock engine except for springs, and the Holley EFI system
Can you guys size the turbo(s), trans, and gear to make an exceptionally responsive street car that can still run low 10's and maybe even dip into the high 9's?
Great to see you back in the turbo world Vince!
Loose converter and something like that t4 S400 would spool instantly. I had a regular $450 PTC turbo converter and it spooled instantly, come to find out it was running on 7 cylinders the whole time. I had PTC tighten it up while still unknowingly on 7 cylinders and the spool time was longer, kind of removed some of the fun of the car, but I didnt miss the CVT like shift of the looser converter, but just comes with the territory. I put a T10 in the car and the spool got even worse even on 8 cylinders once figured out. Some people will tell you they can spool twin PT91s on a stock 4.8 with a clutch but neither of us had much luck with more reasonable combos and a clutch.
Interesting thing on the cheaper PTC turbo converters, one was very loose and the other quite a bit tighter, but they both cruised on the freeway very very tight. Only when you put your foot down could you notice a difference in "looseness"
Depends on what your definition of exceptionally responsive is. A 6768 or 7168 would make instant boost with a tight converter and be very fun on the street. It's not going to take much power to go 9's in an sn95 with any some weight pulled out and a good 60'. A 7675 would be my choice. They're capable of low 9's in a full-weight car and will still spool plenty fast.
5.3 or 4.8 and a little mpt 70 on 14lbs and you've met your goals and them some. My 5.3 with the mpt 70 ran a 10.50 @133 the second time out on 9lbs. I'm running a PTC 10" converter and 3.08 gears with a th400. I haven't even started to lean on it yet.
PS- I'm also running the Holley, you'll love it.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I do like the s475 t4 I had, but not sure how it would act on a 4.8/5.3. I'll get whatever engine I can get cheaper cause this is a budget build (as usual). Going to try and spend the money where it counts though - convertor/trans, efi ecu, etc. What trans an gear were you running?
Great info thanks!!!!
Vince, my car has a th350 and 2.41 rear gear and 27" tires(255 drag radials). I look at it as a powerglide with an overdrive with that super tall gear. I'd choose 2.73 or 3.08 gears and a th400 for your car if you run 27" or 28" tires.
I have a rebuilt MP T-70, .68 (great for a 4.8, in fact that's what I planned on using) with a polished compressor cover I'd sell for $450 shipped. I'm fabbing my setup from the beginning with a T6 for my S480 with race cover going on the 370. Pics are of the actual turbo, compare it to an S475 lol.
Think a 3.08/3.23 gear would work? Reason I ask, is I'm looking for a take-out 8.8 GT rear and most have 3.23 from what I;ve seen. But then again, maybe a 4.8 would need more gear??? If that's the case, might as we'll get more motor to pull the 3.23's
cause gear changes aint cheap
The 3.08's or 3.27's that come in the 8.8's would work great with either motor. The 2.73's are steeper than what I would run but even they would work. 8.8's are very cheap to build anyway. At least pull the trac-lok out and rebuild it with new clutches and one extra friction on each side.
