People with the Kurt Urban Performance steam vent system come on in..
How are you guys routing the return line to the radiator? I understand that the collection block is the high point but, wouldn't going "down hill" back the radiator pose a problem? Any advice, opinions, tips or pictures would be greatly appreciated!
There's another thread on this with heaps of pictures, can't find it though.
Here's mine. I've added a T-piece to the left there where there's a gap which runs through to a free port on my radiator low-pressure side.
If you have ever seen how much coolant/ pressure comes out of those steam ports you will realize that it doesn't matter that the block is the highest point.
Although in mine my rad was lowered so I have an expansion tank mounted to the passager side head and it is level with my block for the water vapor kit
I have the single return line at a slight upward angle to promote flow back to the radiator. Hard to say if its working 100% efficiently like that, but its better than not having the rear of the heads vented at all.
Yes that is my Fill point for the hole system. IT it very easy to fill my system and get all the air out set up like this. The bottum port on the surge tank goes to the top of the rad and the port on the side goes to the water vapor system. I did it like this as I dropped my rad down about 2 inches and pushed it forward.
http://www.jegs.com/p/JEGS-Performan...06363/10002/-1
Get one of these and tee it into your upper radiator hose.
I was thinking about just having a -4 AN bung welded into the radiator right below the cap. Would that work?
The best is if you could keep it going uphill, that is possible in about 1 in 20 cars! Most in the pictures seem decent. The most important part is going up from the head to the collection block, then having that 5th port highest. Once the air collects in the block and gets into the single line even an electric water pump can push the air down if needed. Post two shows line installed on the head then going down, this is bad as air will trap in the high part of the single line if flow volume is low.
Kurt
Kurt
Kurt
Kurt
