***LQ4 S475 E85 Non-Intercooled - Daily Driver***
#121
This car will rarely be out at night. Also, I am sure that the hellas will have greater light output than the stock POS headlights.
#124
I love my s475... They are big but i made mine go where i wanted it too... I have stock bottom end ls1 with a big tick cam and it spools 5psi at low 3000rpm range and by 4200 its screaming. But for 650 dollars like the post says you cant beat them.
#128
Yea, I really don't care about being legal. As long as I can get a decent light output, without blinding oncoming traffic, Ill be happy. If I get hassled, Ill throw some useless LEDs at a "proper height" to appease the law.
The downpipe...
with the 4" I was able to find a 6" CLR, which in my setup gives me a 16" straight section, I could only find 5" with a 12" CLR, which drops the straight section down to ~8". I wan't to put a muffler in the straight section, big as possible obviously.
I am going to build a secondary 5" aluminum DP, that will exit out the headlight cover, with a big horn... just for fun,
#133
#135
Trevor "daily drives" a CJ jeep, so OBVIOUSLY the requirements for functional daily driver are pretty minimal.
T6 was a good call.. The borg T6's obviously are not anything like the T6's of legend in the Garrett world, they work quite nicely... If it wasnt for my turbo kit being basically nonconvertible I would probably run a T6.
#136
O ****, the troll has arrived
but you're right, Im not a pansy, I could drive the 7-series if I wanted to be a baby.
Also, its a TJ...
Also, I took a screen shot of that already, so don't bother editing... It is on record that Scott just agreed with a decision I made.
Also, its a TJ...
