INTERCOOLERS Thoughts on air v water
Water is 14 times better than air at removing heat from aluminum. There will NEVER be an air to air thats as good as an air to water. You cant argue otherwise.
If you plan on running any kind of HE then you are actaully running at 50% the effcieny of a air to air unit as the energy (heat) has to move twice - once from the air to the water and then from the water to the amibent air. yes you have greater themal capacity than an air to air unit, but the system recovery times will be higher also.
If air to water is soooo great i guess someone should be telling GM, Ford, Mitsubishi, Subaru, Nissan, BMW, Porsche, Ferarri, McLaren, VW/Audi (inc the their race cars) they know NOTHING about cars as thats what they use! In fact why dont you go tell Bell and Garrett that they should stop selling air to air intercoolers and stick to air to water setups!
I argee that air to water has its place, and that is in 1) race cars that can use iced water to get sub-ambient air temps / not require airflow for the IC & 2) cars where you cant get enough ambient airflow to the intercooler core (i.e. mid engined cars even though most manage it pretty well (look at ALMS cars)).
I have this kit so I will speak from experience. Let's put it this way if you have a capable A2W system if the water in that system is the same temp as the air outside it WILL STILL cool the air BETTER than an A2A system. This is what guys are missing when those of us who understand these systems are saying they are more efficient. Then add that you can add ice to aid on top if that. You can never get colder than ambient air across an A2A system unless you are fogging freon across it.
Guys like you spouting this ignorance is what ruins a board like this for guys who come here for advice. No insult intended I am guessing you are repeating something you thought you learned. You just learned wrong. Not your fault.
people just don't understand how these systems work.
Like i have said before, its about a properly designed system which just doesn't seem to be the case with most setups you see.
OEM's use both setups, so they can't even decide which is "better". Look at your application, design the system using properly sized parts and let it eat
I have ran air to water intercooler setups that were tank only with no heat exchangers. Ive driven 600 miles on road trips driving NORMALLY and the water was never more than 20-30 degrees above ambient for the duration of the trip. And yes i monitored it. I had a temp sender in the tank.
Are you guys forgetting that the intercooler is a heat exchanger and it works both ways? If the water is warmer than the air flowing through the system... guess what.. the delta flow reverses and it starts cooling the water.
This isnt rocket science... just thermodynamics.
All i know is an A2A has its place for alot of people
Is it simple? Yep
Is it lighter? Yep
Can it be fairly efficient with a good core? Yep
Nothing more, nothing less
If i had had hood clearance enough to incorporate a liquid core into the intake manifold i would be more than tempted
I'll setup 2 out door cookers,"we call them crawfish burners where I'm from".
I'll set any A/A core on one cooker and a 6 gallon pot of water on the other.
Fire up the burners and I'll put my hands in the water and you put your hands on your best A/A core and let's see who chicken's out first!
You guys line up and I'll bring my suitcase to take the money home in.
You may see higher in boost temps with an air to air but the recovery time is soo quick you can get straight back in the boost with no waiting around/driving waiting for the system to recover.
