INTERCOOLERS Thoughts on air v water
Currently have a 600/300/100 intercooler making 800hp.
Reviewing my options-
1. air intercooler larger and have it over the radiator, looks neater.
2. liquid intercooler "i have never or have any experience"
questions looking for better IAT prep for greater boosting and into 1400hp once new combo is done.
photos of your combo
where to buy
get advice
appreciated.
cheers!
Budget?
From my research in General: A2W is better for mainly track cars, A2A is better for street cars.
A2W is more complicated, has more points of failure, weighs more, and costs more; but has the ability to increase the cooling capability for short durations (IE: Fill the reservoir with ice before a run down the track).
A2W is used in a lot of factory applications though; ZR1 Vette, Cyclone, Lightning, etc.
A2W setups normally have a second dedicated radiator just for the intercooler system if they're run on the street; this allows them to dump heat more efficiently.
That all being said, most people run an A2A if they have the frontal area in the vehicle such that the airflow through the Intercooler is sufficient to cool it properly.
Personally, I'm going with an A2W setup; my bird doesn't have large enough openings, and wouldn't without looking "odd" to make an A2A work.
The whole street vs. race with A2W that you read on here is just ignorance with remarks to A2W being more geared to racing. It's better at removing heat from the air no matter where your at. I have a 6 gallon water tank and you can't over come the heat exchanger for the water. The water never seems to get hotter than ambient. And it shouldn't. Just because you can drive farther than a 1/4 mile at a time on the street doesn't mean you are heat soaking an A2W system any more than an A2A system.
But you get the point race is the aim.
guys just throwing it out there?
pump to front engine bay
exhanger front of car
ice/water tank under front guard
OR
could you put it in the boot for a larger one?
how long will say 4 gallon water / ice last on the street before it losses its abilty to cool?
Unless its a drag car or you cant find any way of getting airflow to the core (without impacting the radiator too much) go air to air.
Thats correct sirrr. Have twin 6265 on my vette with twin pt500 air to water coolers with a large heat exchanger. Only a two gallon res in the rear and my car has GREAT IAT even in 107 degree heat.
I was looking at that very unit, any results you have found??
Hope to it this month though and be driving shortly after that. I HAVE used these intercoolers on other builds though and have never been disappointed in the results. I have not used this exact intercooler, but I am sure it will work just as well. I have always used a tank though and either set it to circulate constantly or on a pressure switch while in boost. I have heard of a timer you can set up to have it circulate for a certain period of time after being activated by a pressure switch....trying to find one of those! Water is 14 times better than air at removing heat from aluminum. There will NEVER be an air to air thats as good as an air to water. You cant argue otherwise.
