Boost leak around Injector O-rings
You should be worried more about fuel leaking at the rails.
Jump your fuel pump to run constant. (motor not running)
Add same amount of air psi to your vacuum line as your boost. (for 1:1 regulator)
If your running 65lbs fuel pressure & 20lb boost = 85lbs fuel pressure needed
your theory is flawed..........
The following users liked this post:
rob_mcarthur (05-03-2023)
