Just picked up a FI car D1SC
Old Feb 11, 2013 | 04:08 PM
camarochvy21's Avatar
Default Just picked up a FI car D1SC
As The title said, I just picked up a 99 SS with a D1SC. What do I need to look out for/need to know about a FI car. I did a little bit of reselpearch before buying, but thought I would ask the pro's for tips and tricks. Thanks for all your h
Old Feb 11, 2013 | 06:08 PM
Texhotrod593's Avatar
I would just change all the fluids including the procharger oil. I might even think about having it tuned to make sure its all good and then just enjoy it man!
Old Feb 11, 2013 | 06:34 PM
I8UR4RD's Avatar
belt swap
oil swap
and like dude said take a look at the tune.
sit back and get addicted to boost.
Old Feb 11, 2013 | 09:12 PM
4kiro's Avatar
I bought a FI car too last year. First thing I did was buy a wideband. Change the cars oil, procharger oil and plugs. My gap in the plugs was way off, varied from .35 to 40. Then I noticed my car was getting hot. Hooked up a scan master and noticed the temps were 220 to 240. The stock gauge read 210. Found out my fan was not plugged in. Wouldn't hurt taking a good look at the drive belt and procharger belt.
Old Feb 12, 2013 | 12:39 PM
thanks guys for all your help
Old Feb 12, 2013 | 01:36 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
Just like everyone else said, go over the setup to make sure you 1, don't have belt slip, 2, don't have a boost leak, 3, you have enough fuel to supply how ever much boost your running, and finally make sure the tune is good.
Old Feb 13, 2013 | 05:15 PM
I read the prochargers instructions, but I looked at the charger today under the hood and cant seem to locate the dipstick on the blower itself? Am I looking in the right place? On top of the blower next to the placard?
Old Feb 13, 2013 | 05:32 PM
lmt0705's Avatar
its an internal screw with a slot for a flathead screwdriver, its tough to see it thru the power steering hoses but its there. dont overfill the blower when you change the oil! youll blow a seal
Old Feb 13, 2013 | 07:00 PM
conan's Avatar
Get a new bottle of procharger oil and change it. It takes 1 bottle that procharger measures out...(easy) Here is a pick of the dip stick. Take out the screw and there is a steel cable attached to the bottom.
Old Feb 14, 2013 | 12:42 AM
Thanks conan
Old Feb 20, 2013 | 05:55 PM
So I finally got the car in the air to change both oils. Well I changed the engine oil and when i looked to change the blower oil, I found the drain plug, but there seems to be a bold sticking out, blocking the hex nut to get a wrench on there. Anyone got any incite on how to do this? Sorry for all the questions!!! Thanks!
Old Feb 20, 2013 | 09:25 PM
Anyone?
Old Feb 20, 2013 | 09:53 PM
I8UR4RD's Avatar
snap a pic of it. often hard to diagnose what is not right in front of you or that you cant see.
Old Feb 20, 2013 | 10:08 PM
Yea i tried, but it was to dark in the stall
Old Feb 22, 2013 | 10:45 AM
This is what it looks like. http://www.performancetrucks.net/for...w-plug-411218/ Can I take that allen screw out and then the drain plug? Need some help guys
Old Feb 22, 2013 | 12:17 PM
conan's Avatar
Those allen key bolts are for "clocking" the head unit. You can remove one of them to drain it with no problems, there are 7 of them on my blower. I took some pics of it I'll post up when I get home from work.
Can you get some pics with a flash of your head unit ? It might be clocked differant, because my drain plug is clear of those plates with the allen head bolts.
Old Feb 22, 2013 | 03:17 PM
I just changed the oil in the head unit and holly **** that was a BITCH!!!! Thank god i only have to do it every 6000!!
