looking for input on building a motor for an F1A
The question is what heads to use? Seems like the afr 225's are a tried and true head, and I can use a vic jr intake and only notch the cowl a little. Or would a ls7 style head make more power? and what intake could I use that won't require losing the cowl?
Thanks
If you are running a single plane with boost, 4bbl TB and a EV hat is the only way to go, but I would still opt for the tunnel ram
put the money elsewhere, you can always sell it and swap it later for fun and see what it picks up for reference.
Maybe you were reading or typing with your one good eye, lol. I know a little more than you might think. With methanol and the right plug its safe. If you are running on the ragged edge of knock then yes its not safe. If timing is backed off to a safe limit, then yes it runs NICELY. Show some proof of the egt spread on a car with conservative timing and methanol. I under stand they can vary but keep timing at a safe limit and spray some methanol on it and its not a problem. There are a lot of big powered cars running this setup and still alive. I do understand what you are saying and yes its true, but in the lower hp cars its not a critical. One last thing, does it suck to be angry all the time? ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
