High HP E85 Turbo Tune
Yes, I am hitting the track Saturday and maybe sunday. I do plan to try and lean it up a little. I also have to figure out why it is at 13.5 degrees of timing at WOT. I have it at 16 but when I log it is at 13.5. Something is causing it to pull timing. It must be from IAT or coolent temps. That is the only thing I can think of. I am still new to tuning so hard for me to decipher this **** most of the time. If I can get it to run the 16 degrees at WOT I was planning to bump it up to 17 and then 18. I have no plans to go any higher than that at WOT.
I got everything done except the drive shaft in. Hopefully it will be ready to pick up tomorrow. Then I can fill it up with fluid, fill up with water in the radiator and get all the air out and hopefully drive this thing on the road a couple days first and do some logging on the back road.
I will let you all know how it does. My plan is to strictly work on the launch. We know it runs well on the big end. However, it will never ET good unless it launches well. If things go well I hope to launch this thing at 10lbs of boost and get some 1.4 60fts. If it does it will make some low 6 passes.
Oh yeah, I almost forgot. I ordered some BR7ef plugs and will try them for the first time. I have been running the NGK 5724-8's
my timing table never matched to my data logs. when i wanted to change timing at wot i would follow through and figure out which cells my timing was low and add however much to that cell to achieve my timing goal.
ex.
heres a log i have. you can see that that cell shows 17* timing
heres the exact cell in my tune which shows a commanded 16* timing
lets say i wanted to have 18* timing. i would add 1* to that cell in my tune even though i would be commanding it at 17*. i would go and do this to every cell that got hit in that wot run and adjust each cell according to what the data log says. even though my tune file has a target of 16*, it may not put out that much timing. idk if this is the right way but it worked for me lol. theirs more than one way to skin a cat
ex.
Question: I noticed your timing was crazy high in the top part of that chart. Is that where you were trying to build boost on the transbrake? The only reason I ask is 33 degrees is as high as I had mine in that category. I didn't want to change that area to the 50's like yours but I just added 10 to all of the cells in that area.
that timing table was used with my previous 5.3/t76 when i didnt have a trans brake. i never touched that part of the timing table because i dont think it was ever used. i cant remember if that was in the 50's from the stock tune or what but my timing has never been that high lol. atleast i dont think
I read the plugs more than anything else. However, that is an art in itself and plenty of people have posted the plugs looked great and then boom!
I just wanted to make sure I was in a NORMAL zone. I think I am.
Yes, I have the MSD 2 Step
Anyways, I couldn't wait until morning so I tried it in the garage. It worked a little better so it definitely helped. I built boost really quick once I actually tried. I stayed on the button until the throttle went back down. Didn't want to let the button go in the garage. lol
