High HP E85 Turbo Tune
Old Feb 15, 2013 | 11:22 AM
tom robison's Avatar
Default High HP E85 Turbo Tune
I was just wondering what a/f ratio and timing you are running on cars make over 900hp. I am building a 6.0 with 317 heads, 10-1 comp, manely rods,stock crank, custom cam, victor jr, air to water and a precision LF85 turbo. I was going to start in the 11.2 a/f and 16-17 degrees of timing. I will also be using leaded e85. I will be running enough boost for 1000rwhp if it lives. Thanks
Old Feb 15, 2013 | 06:01 PM
oange ss's Avatar
Leaded E85 ?
Old Feb 15, 2013 | 08:08 PM
Yes, leaded e85. Mixed with leaded gas , not pump gas.
Old Feb 15, 2013 | 08:15 PM
Bill_Ritter's Avatar
where are you getting drums of leaded e85 in our area?
Old Feb 15, 2013 | 08:19 PM
From S and M Motorsports.
Old Feb 15, 2013 | 08:27 PM
98Z28CobraKiller's Avatar
Restricted User
but a/f target would be the same. i'm guessing they are mixing it with race gas which should raise the octane a little more meaning that it might take a little more timing than the regular stuff.
Old Feb 15, 2013 | 08:30 PM
Wicked69's Avatar
If I was going to buy drums and NOT get it from the gas station, I would just run Alcohol. It is a whole lot cheaper by the barrel. I run E85 because I can get it anywhere from the pump in my area.
To your question though. I have no idea of what hp I am but I have run a 118mph in the 1/8th in a 3870lb chevelle. I have to be close. Anyways, I make sure that I never hit 11 anything at WOT. That may be a little conservative but it seems to work. I try to stay between 10.5 and 10.8 at full boost. I also run a lot lower timing than most also.
Old Feb 15, 2013 | 08:55 PM
Restricted User
118 would be somewhere in the 146-148 mph range and at that weight is pretty close to 1K rwhp.
IMO, 10 anything is too rich, Specially with E85. Too fat lifts ring lands. The additional fuel volume of the E85 adds to that risk. I'd rather error on the high side of 11's.
Old Feb 15, 2013 | 10:02 PM
Wicked69's Avatar
Really. That's interesting. When I blew the last motor it was on 23lbs of boost. It was fine on 20lbs. When I pulled the motor apart. Of course the number 3 and 4 pistons were completely gone. lol Anyways, the other pistons and rods all looked good. None of the ringlands looked bad.
I am very new to tuning though and definitely am still learning. So I would take what I have done with a grain of salt. Based on your information though, next week at the track I will go ahead and try the low 11 range and see how she does. Being too fat might be why I am having a hard time getting her to leave.
Just to clarify, we are talking about using the gas scale? Correct?
Old Feb 15, 2013 | 10:14 PM
LS1NOVA's Avatar
Mine isnt 1000hp but around 18 degrees timing and 12.2afr on E85. 717whp on 17lbs. (PT76 5.3)
Another one I work on is 1000whp, 18 degrees timing and 11.2ish AFR on 21lbs. (Twin 67's on a 427)
Old Feb 15, 2013 | 10:37 PM
Restricted User
Correct. We've lost a pump on LS2Formula's car (7.7 @ 183) half way down the track (danger of running multiple pumps) and thanks to the Holley ECU hitting 300% duty cycle on the injectors LOL, it stayed in the 12.7-12.9 rang out the back door and didn't hurt a thing. E85 is very forgiving. We've just found that his car wont go any faster than the 11.5-11.8 range. Haven't tried it on a dyno but 1400ish rwhp is hard to hook on the rollers and makes swiss cheese of a set of tires in no time flat.
Old Feb 16, 2013 | 02:08 AM
Wicked69's Avatar
Great info. This gives me something easy to tune and is great info for the OP. I can post some results and see how much she picks up. Probably a ton of ET.
Thanks man.
Old Feb 16, 2013 | 01:09 PM
Ryans99ls1's Avatar
11.0-11.3 keeps my stocker alive at 19* timing with E85. Not in 900 range but if it keeps the stock pistons intact it cant be that bad of a target AFR
Old Feb 16, 2013 | 01:13 PM
Grr's Avatar
Grr
11.3-11.5 and 18-21* depending on air temps
Old Feb 16, 2013 | 05:30 PM
2JZFC's Avatar
There is a distinct difference in how my engine runs at 11.5:1 versus 10.5:1. Makes more power with more fuel and I keep timing at around 18-20*. Never dyno'd the engine but can't argue with the numbers. 6.0L with 9.5:1 Mahles, Eagle rods, TU1 cam, untouched 317s and a Pro-Flo.
Old Feb 16, 2013 | 07:28 PM
CameronVic's Avatar
What boost and 19*?
Old Feb 16, 2013 | 07:57 PM
Good info, thanks to all who have replyed. What plugs is everybody running?
Old Feb 16, 2013 | 08:06 PM
Wicked69's Avatar
It seems the consesus is the BR7ef plug. I was running the NGK 5724-8 but it is a projected tip. I haven't had any problems with it and car runs great but am always willing to try and see if she can run better. I just ordered the BR7ef plugs today and will give them a shot.
Old Feb 16, 2013 | 09:42 PM
LS1NOVA's Avatar
Br7ef.
Old Feb 17, 2013 | 06:48 PM
Ryans99ls1's Avatar
Originally Posted by CameronVic
What boost and 19*?
Starts at 12lbs and falls linearly to 9.5lbs at 6k. (it made 630 with 22* in it)
Running TR6's now, probably gonna switch to BR7s
