High HP E85 Turbo Tune
Old Feb 20, 2013 | 10:50 PM
  #41
T76s10's Avatar
That's bad ***! Sounds like she's getting spooled. What's your timing at on the brake?
Old Feb 20, 2013 | 11:04 PM
  #42
Wicked69's Avatar
Low 30's
Old Feb 20, 2013 | 11:09 PM
  #43
Wicked69's Avatar
For those wondering if the Power Glide would still launch my heavy *** car. Here is my first test pass this morning with the Power Glide and 3.42's, plus a 30" tall Drag radial.
I think she passed the test. This was on 5-6lbs of boost.
Old Feb 21, 2013 | 10:28 AM
  #44
DBRODS's Avatar
Originally Posted by Wicked69
Okay, good to know. I did find on the histogram where my timing was low in the scanner, and then went into editor and made the changes by adding the appropriate degrees to get it to 17 degrees at WOT. I will see how it does there First.
If you are using Hptuners to log then add burst knock to monitor also. I guarantee that is whats making the timing not match.
Old Feb 21, 2013 | 05:43 PM
  #45
Wicked69's Avatar
I log burst knock. Mine is never 2, sometimes it is 1. something but never 2. I thought anything below 3 is okay.
Anyways, we had an ice storm today. It figures. However, I spent 7 straight hours trying to mess with retarding the timing and leaning out the fuel mixture in the cells right before and after the car hits 7-8 lbs of boost. I also had to wait an hour between each try because I was forced to try this in my garage. Don't want to accidentally forget to let the transbrake go. lol
Well I got it to work. I am shocked I got it to work. I was able to get 10lbs of boost on the foot brake and 13-14lbs on the transbrake. I was able to get it pretty quickly. Surely if I can leave with that much boost my car is going to do well on the front half of the track.
In the video I went ahead and showed all my guages to show where I keep everything.
Old Feb 21, 2013 | 09:51 PM
  #46
DBRODS's Avatar
http://www.youtube.com/watch?v=i9Wmty7C8Oo
I always just get rid of burst knock since its not real. What did you finally end up doing to get a few extra pounds? Leaner a/f and less timing?
Old Oct 30, 2013 | 10:39 PM
  #47
n20z28's Avatar
I'm new to tuning will high iats cause a problem with ur tune up? Detonation and such
Old Oct 31, 2013 | 04:56 AM
  #48
samdogmx's Avatar
at 20 psi boost no IC, I aim for 10.8-10.9 afr, timing starts off at 15* then pulls to 11ish as IAT climb, br7 plugs
I plan on truning the boost up a tad more & I feel like it could take some more timing & possibly lean it to 11.0 what you guys think?
