Dual Fuel on the fly(87 and e85) on stock pcm's!
Old 02-21-2013 | 01:46 AM
itsslow98's Avatar
Originally Posted by 95bowtie
My guess was hobbs switch kicks e85 pump on and grounds injectors on second pcm at the same time. Second e85 pcm is prolly signaling the 80lbers to fire but if they arent grounded yet they dont do **** till 2 psi.
Stock pcm/injectors do all the idle and part throttle driving and also manage the full timing table. Second e85 pcm only controls the second set of injectors would be my guess.
It makes sense but your still relying on a single swtich to switch fuels....if that fails then kaboom.
In the original posts he says no having to worry about a meth pump failure so I dont really see the safety factor being that much greater if that is in fact how he is doing it.
Old 02-21-2013 | 02:31 AM
PROLSXSS's Avatar
More info please?
Old 02-21-2013 | 04:34 AM
Sarg's Avatar
I am sure you could build in a redundant second switch and warning light if the first fails.
Old 02-21-2013 | 04:52 AM
Wicked69's Avatar
I still like the idea of haveing two seperate tanks and just open a valve to use which ever fuel and change the tune. No second set of fuel lines, pcm, injectors, etc...
This is still a very cool idea though. I just like to be very, very simple. lol
Old 02-21-2013 | 05:42 AM
JAX04's Avatar
Originally Posted by aknovaman
Ancient Chinese secret but very easy.
Its 2013 and This is America....
LS1NOVA's Avatar
You guys should ****** up that dual injector sheetmetal Hogans intake from Competition Products broom sheet that has been for sale for $1000 forever.
Old 02-21-2013 | 06:15 AM
skinnies's Avatar
We talked about doing it that way for awhile, but being able to drive down the highway and that bike pulls up next to you makes it no fun that way. This way we can just mash it and race, no waiting or anything.
Originally Posted by hardrock21
So, I'm guessing both PCM's are firing all the injectors all the time? The only variable is some sort of hobbs switch cycling the different pumps? So, one set of injectors is firing dry all the time? Or, is it more complicated then that? Nice work either way.
Edit: I guess this way wouldn't really allow for different timing tables and such as the tunes would have to be identical minus the fueling...
Paul
No injectors all don't fire all the time. Pumps have to be on all the time as you have to maintain some type of fuel pressure since boost comes on so fast.
Not a single switch, it has plenty of failsafes built it, no way possible for it to ever be on pump gas in higher boost.
So in boost the 87oct injectors shut off? I was assuming they just run max and the e85 system adds in the rest once its activated....
They shut off completely, leaving them on would dilute down the e85 and lower the octane, not ideal on a high HP setup. If someone wants more than 1300rwhp then easily can run e98. This setup on maxx's car was built so an injector and tune change and can be 1500rwhp capable.
As mentioned above, if you do it this way you would not have fuel pressure when you went into boost, talking a split second change from vacuum well into boost, kicking on the fuel pump at boost wouldn't work. The 1st pcm controls all timing and pump gas injectors, 2nd pcm controls e85 injectors. It's not as simple as it sounds honestly, LOTS of little tricks to making it work right and if you aren't careful when tuning both you could EASILY hurt something.
Old 02-21-2013 | 06:18 AM
JAX04's Avatar
Perhaps the name of the thread should've been
"Dual Fuel on the fly(87 and e85) on stock pcm's!- Teaser"
Just razzin' ya...
Old 02-21-2013 | 06:20 AM
skinnies's Avatar
Just razzin' ya...
I've gave out a lot of info on it, sorry I'm not giving out a wiring schematic, diagrams, and tune. We've got a lot of time/testing in making this work smooth and flawless. To my knowledge nobody has done this before with 2 pcm's and pump and e85.
Old 02-21-2013 | 06:23 AM
JAX04's Avatar
I get it man. hence the " Just razzin ya"
I understand.
Old 02-21-2013 | 06:50 AM
Somebody09's Avatar
that's smart as hell!
Old 02-21-2013 | 06:58 AM
  #32
js2fst's Avatar
They have alot of time and work in it I have seen it I am sure knowing these guys they got it to work!
Old 02-21-2013 | 07:22 AM
  #33
71 chevy's Avatar
I'd like to add, the cost to do something like this if say building a 1200-1400rwhp car wouldn't be THAT much more than building a single fuel system from scratch. Great thing is you could leave all the stock tank/pump/lines and just change them for aftermarket rails so wouldn't cost much. Then you have the cost of the intake modification, fuel cell, fuel rails and pcm/wiring really is the only extra cost. Being as you would need 1 set of rails anyway, would need big lines front/rear anyway, aftermarket regulator, etc. In the end the cost isn't that much more and a much better option than trying for big power on meth in my opinion.
do you have to split all the pertinent engine signals to BOTH pcms? ie, tps, clt, iat,mat? o2?
obviously, the MAP signal is split. or are you using two map sensors?
very neat setup
Old 02-21-2013 | 07:33 AM
  #34
SUPERWAKE502's Avatar
Probably uses j1939 communication wires between the two computers. If the second computer is on the first computers network then it should read all the sensors from it.
Old 02-21-2013 | 07:37 AM
  #35
skinnies's Avatar
very neat setup
Some yes and some no, splitting of some sensors will not work optimally we have found.
Didn't use that
Old 02-21-2013 | 08:39 AM
  #36
KC Henry's Avatar
Well done, and even better that it is from KC guys.
Old 02-21-2013 | 08:46 AM
  #37
SMOKNSS's Avatar
Nice work guys. Pretty damn cool thing to do for a street car.
Old 02-21-2013 | 09:15 AM
  #38
quicksilverado's Avatar
So when are you gonna start selling these dual fuel systems?
Old 02-21-2013 | 09:33 AM
  #39
PewterZCar's Avatar
Hats off to you guys. That is a great idea. Now I won't have to have someone following me with 40 gallons of e85 for a night of racing
Old 02-21-2013 | 10:15 AM
  #40
Area47's Avatar
congrats on getting this done fruit cakes. last time i was out at the shop maxx was talking about it.
Quick Reply: Dual Fuel on the fly(87 and e85) on stock pcm's!
