Best Meth Injection Kit?
Old Mar 9, 2013 | 10:28 PM
  #61
Tjabo's Avatar
They use essentially the same pump now that all of the other good kits I've seen use. They used to be all about injecting 100% water, but then kind of accepted the fact that there are a lot of good results from adding methanol or isopropyl alcohol to the mixture.
Aquamist really hasn't embraced the idea of 100% methanol though because of the heat absorbing qualities of water in the combustion chamber. Basically they want people to use about 50% methanol or less, and just inject more of it if you want a lot of methanol going through the system.
Old Mar 9, 2013 | 11:03 PM
  #62
tta656's Avatar
Back 15-17 yrs ago SMC came out with the first Alki kits(Buick Grand Nationals)...they are so simple to make in a basic form ,thats why their are so many diff ones out there,the Aquamist looks like a nice kit ,but fck that price, i will build my own with a tank,pump hobbs switch and some nozzles..and be done
Old Mar 10, 2013 | 03:19 PM
  #63
TheLS1Lover's Avatar
Aquamist or Alky Control are the best IMO.
Old Mar 11, 2013 | 06:36 PM
  #64
MonmouthCtyLS7's Avatar
This thread blew up...lmao....
Old Mar 24, 2013 | 10:14 PM
  #65
Dayton937's Avatar
bump
In the market for a kit
Trying to choose between:
Aquamist
AlkyControl
Devil's Own
My reluctance on just getting the Aquamist is that freaking price tag...
AlkyControl seems like the go-between
Devil's Own seems like a good quality kit for the $ from the research I've done
Plus I like the fact that Julio appears to know what he's talking about
Old Mar 25, 2013 | 12:32 AM
  #66
Wicked69's Avatar
Originally Posted by dville_gt
what a cheap ***!
Are you using an intercooler also?
I am adding an intercooler but if it slows it down and doesn't drop the IAT's enough. I plan to remove the intercooler and make my own kit and run straight tap water. Can't go wrong when a guy who runs 5.60's makes is own on a daily driver.
Old Sep 17, 2013 | 04:14 PM
  #67
projectbirdshot's Avatar
hate to be flamed for a bump, but better than posting a new thread. Im green as well on this topic and was just wondering what the consumption rate of a meth injection system is? I mean does it burn through the meth/water solution like its going out of style or does it last a substantial amount of time between meth tank fill ups?
Old Sep 17, 2013 | 04:46 PM
  #68
Julio's Avatar
Your consumption is based on HP(airflow) and boost. If your in boost spraying then your consuming. Driving around town normally=zero consumption.
1 gallon can last 5 minutes or 3 weeks.
Old Sep 17, 2013 | 04:48 PM
  #69
ls1curt's Avatar
A 5 gallon drum lasts me all year. Like Julio said, the only time you use it is when your in boost.
Old Sep 17, 2013 | 04:50 PM
  #70
smokeshow's Avatar
Originally Posted by Julio
Your consumption is based on HP(airflow) and boost.:
Have you changed your kits to incorporate airflow as an input?? If so I want details and an upgrade
Old Sep 17, 2013 | 06:17 PM
  #71
35thsscamaro02's Avatar
I was ais but wouldn't use anyone other than alkycontrol now. Dave "DSX Tuning" and Julio just set me up with a great progressive controller that uses a ls7 maf to activate it.
Old Sep 18, 2013 | 12:01 PM
  #72
GMouldy's Avatar
Is there anyone out there that i can buy just the control boxes for?
I had an STS kit with the methenol injection kit and since then, i have went to a front mount and have gotten rid of all the STS wiring. I have the pump tank, lines and nozzle, so is there anyone that makes just the brain boxes i can buy?
Old Sep 18, 2013 | 12:10 PM
  #73
BMF_Racing's Avatar
I've always used Snow kits --- never an issue yet.
Old Feb 23, 2014 | 09:43 PM
  #74
Hi Volume's Avatar
kinda bringin this thread out of the grave, but i really like this kit:
http://www.ebay.com/itm/261190031141?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The truck mounted cell with intergrated pump is very nice. Does anyone have any experience with this kit? I will be buying a meth injection kit soon, like next month, so i figured i would ask. thanks
