Huron Speed Custom T6 or Mid-Frame T4 Turbo Kits!
#41
Thanks Aaron, appreciate it!
Martin's kit has been a lot of fun to build with the cool 5" to split 4" downpipes
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
#42
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Jon, man I'm speechless on the quality of the welds on my kit. You've got some awesome fabrication skills my friend.
DO NOT PAY THE IMPOSTERS TO BUILD YOUR TURBO KIT! Let this guy here do it and be amazed at the quality! Not to mention customer service! No need to worry about if your hard earned money will just poof and disappear as others have done in the past. Jon just doesn't work that way, he doesn't take all of your money up front and just takes what is needed to build the kit.
#43
thanks Martin! Really appreciate the kind words. Few other finishing touches I want to do to your kit to make it even better
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
__________________
#45
What is your set-up consisting of Aaron? Which turbo and what size engine? I'm sure you'll have some bad *** heads sitting on top of it. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
Ill send you a message over with some specs.
#46
No sir. Going to run E85 in the local RS275 class and E100 for anyone that wants to get froggy and see what the Huron Speed sticker looks like on the back of the hatch glass.
I'm also going to be running dual 20gph methanol nozzles with straight 100% M1.
You sneaky devil you!
engarde:
#48
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
I have $50, do I hear $55?
__________________
#50
__________________
#52
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#54
Nothing this pretty with our name on it will be Pink!
__________________
#60
I do not see any heat issues related to the fuse panel either, but we will certainly check out all aspects of heat and take appropriate measures to protect anything that gets warm!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
__________________
